Pickit3 cannot work ?
samnang39
Full Member level 2
Cambodia
Dear all
My PicKit3 cannot work then i connect it to the PC the program show that
what happen with my Pickit3 and how to do it?
thank in advance
samnang39
Full Member level 2
Cambodia
Thanks i try to program with MPLAB IDE but not work and than i try with software Pickit3 it work but now cannot work all
i do not know why?
Tahmid
Advanced Member level 5
Silicon Valley, California, USA (from Dhaka, Bangl
A Google search reveals that this is a common problem (or at least was, a while back).
Try upgrading to the latest version of MPLAB and programming through MPLAB.
I don't know which version of PICKIT3 you're using, but see if this works: https://www.microchip.com/forums/m500342.aspx
Hope this helps.
Tahmid.
tpetar
Pancevo-Belgrade, Serbia
To make PICKit 3 to work and solve this problem, first allow MPLAB IDE to update firmware before you can use it for programming.
Additional to MPLAB you can try to program from standalone application 3.0 :
PICkit 3 GUI and Scripting Tool v3.00 BETA
As you notice its still beta version.
Dont forget to update firmware!!!.
I have to admit that I'm not sure what Microchip wanted to do with the PICkit 3 programmer, works worse than PICkit 2. It is possible that they wanted to increase the sale of devices, because it would be harder to clone by home hobbyst. And in all this they started to play a little more, and we get product result. Of course they are a serious company and this will be solved.
samnang39
Full Member level 2
Cambodia
It is work now but still not work with MPLABX IDE cannot program and Debug
samnang39
Full Member level 2
Cambodia
i can Read and Write with Pickit3 GUI but i still cannot use in Mplabx so how ?
tpetar
Yes I understand, but life often is not fair. :)
Please check that the circuit components are correct for the debugger to work correctly? Here are the guidelines:
- Do not use pull-ups on PGC/PGD – they will disrupt the voltage levels, since these lines have 4.7k pull-down resistors in the debugger.
- Do not use capacitors on PGC/PGD – they will prevent fast transitions on data and clock lines during programming and debug communications.
- Do not use capacitors on MCLR - they will prevent fast transitions of VPP. A simple pull-up resistor is generally sufficient.
- Do not use diodes on PGC/PGD – they will prevent bidirectional communication between the debugger and the target device.
https://www.microchip.com/cisar/Default.aspx?type=pickit3
qwertyuiop415263
Full Member level 4
Pakistan
in Mplabx window right click on your project folder and select Properties. Then choose the debugger as Pickit3. Also search on microchip forum related to this problem. I also have same problem but after reading some posts on microchip forum, i have fixed it. GoodLuck
samnang39
Full Member level 2
Cambodia
the circuit is ok and choose the debugger as Pickit3 but still problem:cry:
