howard.t.sun
Newbie level 3
- Joined
- Feb 4, 2014
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 33
Hi all,
I am not too familiar with motors and I am trying to pick a motor for my current application which requires the rotation of a mechanical arm. After going through the different motors types I realize I would probably need a bi-polar stepper motor (for its precision in position) attached with a planetary gearhead with a high reduction ratio (for high torque). I have calculated that I would require at least 130 oz-in or 950 mNm of torque in order to smoothly rotate the arm but I am stuck on transferring that number to something I can read and compare on the spec sheet.
For example, on the spec sheet of one of the motors it says "Holding Torque (at nominal current in both phases) = 22 mNm" which I take as the torque it would take to move the motor out of its stationary position given that the coils are charged. How do I know how much torque the motor would actually generate? I am also attaching it to a gearhead with a 809:1 reduction ratio at 60% efficiency, does that mean that 22 mNm value now turns into (22 mNm)*(809)*(0.6) = 10679 mNm? Yet on the gearhead's spec sheet there are two items, one for continuous torque at 600 mNm and the other for intermittent torque at 1000 mNm. Which number should I go by?
Thanks
Thanks
