mrcube_ns
Advanced Member level 1
Hi all;
I have strange behavior of PIC18F4550.
I doing some project which send and receive SMS, generally everything working fine (in term of sending and receiving SMSs), but I have problem:
some memory static variables are overlaped one over another so when I put some string in a variable, it become overwritten with part of other strings or with value of some other variable.
I do not know reason.
List of strings definitions are:
static char txBuff[50], rxBuff[251], messText[160], tel_to_send[30], debugBuff[30];
static char const tel[5][16]={
"\"+123456789012\"", //THIS IS FAKE TEL NUMBERS HERE, in my code are real ones
"\"+123456789013\"",
"\"+123456789014\"",
"\"+123456789015\"",
"\"+123456789016\""
static char RecivedTelNum[20];
I have same problem with value of a few static unsigned int variables, which gets value from some other variable without any reason.
ANY IDEAS????
Compiler print this information after successful build :
Psect Usage Map:
Psect | Contents | Memory Range | Size
reset_vec | | 0000h - 0003h | 4 bytes
intcode | Interrupt service routine | 0008h - 0013h | 12 bytes
intcodelo | | 0018h - 0027h | 16 bytes
init | Initialization code | 0028h - 0057h | 48 bytes
end_init | Initialization code | 0058h - 006Dh | 22 bytes
text0 | Program and library code | 006Eh - 1239h | 4556 bytes
text20 | Program and library code | 123Ah - 1775h | 1340 bytes
text6 | Program and library code | 1776h - 181Dh | 168 bytes
text2 | Program and library code | 181Eh - 18C3h | 166 bytes
text15 | Program and library code | 18C4h - 1959h | 150 bytes
text10 | Program and library code | 195Ah - 19E9h | 144 bytes
text7 | Program and library code | 19EAh - 1A75h | 140 bytes
text3 | Program and library code | 1A76h - 1AFFh | 138 bytes
text4 | Program and library code | 1B00h - 1B87h | 136 bytes
text17 | Program and library code | 1B88h - 1BF1h | 106 bytes
text5 | Program and library code | 1BF2h - 1C51h | 96 bytes
text9 | Program and library code | 1C52h - 1CB1h | 96 bytes
text1 | Program and library code | 1CB2h - 1D09h | 88 bytes
text16 | Program and library code | 1D0Ah - 1D5Bh | 82 bytes
text11 | Program and library code | 1D5Ch - 1DADh | 82 bytes
text21 | Program and library code | 1DAEh - 1DFBh | 78 bytes
text18 | Program and library code | 1DFCh - 1E45h | 74 bytes
text12 | Program and library code | 1E46h - 1E81h | 60 bytes
text8 | Program and library code | 1E82h - 1EB7h | 54 bytes
text14 | Program and library code | 1EB8h - 1EE5h | 46 bytes
text19 | Program and library code | 1EE6h - 1F05h | 32 bytes
text13 | Program and library code | 1F06h - 1F1Fh | 26 bytes
mediumcon | | 7D9Eh - 7FFFh | 610 bytes
rparam | | 004Ch - 005Fh | 20 bytes
abs_s1 | | 0000h - 004Bh | 76 bytes
abs_s1 | | 0060h - 026Eh | 527 bytes
abs_s1 | | 0400h - 04FFh | 256 bytes
Memory Class Usage:
Program space:
CODE used 1F18h ( 7960) of 8000h bytes ( 24.3%)
CONST used 0h ( 0) of 8000h bytes ( 0.0%)
SMALLCONST used 0h ( 0) of 7800h bytes ( 0.0%)
MEDIUMCONST used 262h ( 610) of 7800h bytes ( 2.0%)
Data space:
RAM used 0h ( 0) of 7A0h bytes ( 0.0%)
BIGRAM used 0h ( 0) of 7A0h bytes ( 0.0%)
COMRAM used 14h ( 20) of 60h bytes ( 20.8%)
ABS1 used 35Bh ( 859) of 7A0h bytes ( 44.0%)
BANK0 used 0h ( 0) of 100h bytes ( 0.0%)
BANK1 used 0h ( 0) of 100h bytes ( 0.0%)
BANK2 used 0h ( 0) of 100h bytes ( 0.0%)
BANK3 used 0h ( 0) of 100h bytes ( 0.0%)
BANK4 used 0h ( 0) of 100h bytes ( 0.0%)
BANK5 used 0h ( 0) of 100h bytes ( 0.0%)
BANK6 used 0h ( 0) of 100h bytes ( 0.0%)
BANK7 used 0h ( 0) of A0h bytes ( 0.0%)
NVRAM used 0h ( 0) of A0h bytes ( 0.0%)
EEPROM space:
EEDATA used 0h ( 0) of 100h bytes ( 0.0%)
ID Location space:
IDLOC used 0h ( 0) of 8h nibbles ( 0.0%)
Configuration bits:
CONFIG used 0h ( 0) of 7h words ( 0.0%)
Memory Summary:
Program space used 217Ah ( 8570) of 8000h bytes ( 26.2%)
Data space used 36Fh ( 879) of 7A0h bytes ( 45.0%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
ID Location space used 0h ( 0) of 8h nibbles ( 0.0%)
Configuration bits used 0h ( 0) of 7h words ( 0.0%)
Thank you in advance!!!!
Mr.Cube
"\"+123456789016\""
ANY IDEAS????
Psect Usage Map:
Memory Class Usage:
Program space:
Data space:
EEPROM space:
ID Location space:
Configuration bits:
Memory Summary:
Mr.Cube
