gonesr
Newbie level 1
I'm using PIC18f8722 development board. I have to display the voltage output values of a sensor on the LCD present on the board and also store those values onto a SD card. I'm using the Microchip's PICtail Daughter Board for SD and MMC (51583b). I'm using the assembly code for displaying the voltage values on the LCD (demo source program for Voltmeter). I have written C code for storing the ADC values(Output Voltages of a sensor are fed as inputs to the ADC_CH2 and those values are stored onto the SD card). I can perform these two individually.. i.e. I can flash and execute the assembly code on to the board and display the output voltage values on the LCD panel using PICkit3 and then use my C code to store output voltage values on the SD card. But when I try to integrate these both programs (assembly code for LCD display and C code for storage on SD card), I get this "Error - section '_entry_scn' can not fit the absolute section. Section '_entry_scn' start=0x00000000, length=0x00000006" error while building the problem(Linker error). I have tried looking for this error on the Microchip forums, but couldn't understand properly(tried to lookup the start code in C018i, but couldn't understand). Looks like I have to modify my linker file, but not sure what parameters to modify to build successfully.
I'm using MPLAB IDE v8.83 and MPLAB C18 compiler. I have attached both the linker files used separately as described above.
Any help is highly appreciated.
Thanks.
Thanks.
