PIC18F45K222 EUSART serial communication help...
VoltVolt
Junior Member level 1
PIC18F45K22 EUSART serial communication(transmit only) help...
hi everyone, just want to ask is there any problem from the below codes?
I just want to print out "helloword" by using serial communication
I'm using PIC18F45K22 and MPLABX IDE compiler...
The codes can be smoothly run but it cannot be print out...
Btw, i don't have interrupt, it is just a test code....
#include <htc.h>
#include <string.h>
char sendBuffer[11];
char sendPosition=0;
void sendUartString(const char string[10]);
void init()
// Asynchronous Transmission Setup
// 1. Initialize the SPBRGHx:SPBRGx register pair and the BRGH and BRG16 bits to achieve the desired baud rate
        SPBRGH2=0X01;
        SPBRG2=0XA0;
	TXSTA2bits.BRGH=1;
	BAUDCON2bits.BRG16=1;
// 2. Set the RXx/DTx and TXx/CKx TRIS controls to ?1?.
	TRISB = 0b11000000;	//set TX2 and RX2 as output
// 3. Enable the asynchronous serial port by clearing the SYNC bit and setting the SPEN bit.
	ANSELB = 0;	//disable ANSEL
	SYNC2 = 0;	//asynchronous mode
	SPEN2 = 1;	//enable EUSART
// 4. If 9-bit transmission is desired, set the TX9 control bit. A set ninth data bit will indicate that the eight Least Significant data bits are an address when the receiver is set for address detection.
// 5. Set the CKTXP control bit if inverted transmit data polarity is desired.
// 6. Enable the transmission by setting the TXEN control bit. This will cause the TXxIF interrupt bit to be set.
	TXEN2 = 1;
// 7. If interrupts are desired, set the TXxIE interrupt enable bit. An interrupt will occur immediately provided that the GIE/GIEH and PEIE/GIEL bits of the INTCON register are also set.
// 8. If 9-bit transmission is selected, the ninth bit should be loaded into the TX9D data bit.
// 9. Load 8-bit data into the TXREGx register. This will start the transmission.
void main()
	init();
	//now you want to send something, so first load a string into the sendBuffer
        while(1)
		//sendUartString("helloworld");
	strcpy(sendBuffer,string); //please check the correct command,copy string[] to sendBuffer[]
	sendPosition=0; //start sending first char
	while((sendPosition!= strlen(sendBuffer)) && sendPosition<10 )
		if(TX2IF==1)//if Transmit register is empty
			TX2REG=sendBuffer[sendPosition]; //send one more char
			sendPosition++;
Re: PIC18F45K22 EUSART serial communication(transmit only) help...
but from the datasheet it says that
"2. Set the RXx/DTx and TXx/CKx TRIS controls to 1"
So what I did:
TRISB = 0b11000000; //set TX2 and RX2 as input
What is the Fosc used? 16 MHz?
Try this
Code C - [expand]
    TX2REG=sendBuffer[sendPosition++]; //send one more char
    while(TX2IF);
if not mistaken... is internal oscillator?
my internal oscillator should be 16MHz...
Owh!
so I should set my OSCCON? haha
I edited you code and add OSCCON register...
add the configuration bits...
it still not working... :oops:
But it successfully build...
Below shows the code I edited...
#include <htc.h>
#include <string.h>
/* Start of configuration fuses*/
#pragma config IESO=OFF, FOSC=INTIO67,PRICLKEN=OFF,FCMEN =OFF,PLLCFG=ON,BOREN=ON,BORV=250
#pragma config WDTEN=OFF
#pragma config P2BMX=PORTC0,CCP2MX=PORTC1,PBADEN=OFF,CCP3MX=PORTE0,MCLRE=INTMCLR,HFOFST=OFF,T3CMX=PORTC0
#pragma config DEBUG=OFF,STVREN=ON,XINST=OFF,LVP=OFF
#pragma config CP0=OFF,CP1=OFF,CP2=OFF,CP3=OFF
#pragma config CPB=OFF,CPD=OFF
#pragma config WRT0=ON,WRT1=ON,WRT2=ON,WRT3=ON
#pragma config WRTB=ON,WRTC=ON,WRTD=ON
/* end of configuration fuses */
char sendPosition = 0;
void init() {
    OSCCON = 0b11110011; //16MHz internal oscillator
    OSCCON2 = 0b00000000;
    SPBRGH2 = 0X01;
    SPBRG2 = 0XA0;
    TXSTA2bits.BRGH = 1;
    BAUDCON2bits.BRG16 = 1;
    TXEN2 = 1;
    //TX2IE = 1;
    //GIE = 1;
    //PEIE = 1;
void main() {
    init();
    while (1) TXREG2 = 'H';
    //while(1)
void sendUartString(const char string[10]) {
    strcpy(sendBuffer, string); //please check the correct command,copy string[] to sendBuffer[]
    sendPosition = 0; //start sending first char
    //    while ((sendPosition != strlen(sendBuffer)) && sendPosition < 10) {
    //        if (TX2IF == 1)//if Transmit register is empty
    //            TX2REG = sendBuffer[sendPosition]; //send one more char
    //            sendPosition++;
        TX2REG = sendBuffer[sendPosition++]; //send one more char
        while (TX2IF);
hello,
in your post #1 , how do you want to send somewhat with a comment in front of your function.
and add some delay between invoice..
void main()
    init();
        while(1)
        [B][COLOR=#FF0000]//[/COLOR][/B]sendUartString("helloworld");
and in post#5
void main()
 init();
while(1)
    if (TX2IF == 1) //if Transmit register is empty
              TX2REG = 'H'
    // add here some delay !
