P.Copper
Member level 5
- Joined
- Mar 18, 2013
- Messages
- 82
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,807
Can someone help me to figure out whats wrong with my code.. i have coded a simple timer 2 delay using MPABX IDE compiler.. I'm using PICkit3 to test the code.. my problem is that the LEDS on the demo board dont switch on at all
here's my code
title "timer 2 delay"
list P=PIC18f45k20
here's my code
list P=PIC18f45k20
#include "p18f45K20.inc"
; CONFIG1H
CONFIG FOSC = INTIO7 ; Oscillator Selection bits (Internal oscillator block, CLKOUT function on RA6, port function on RA7)
CONFIG FCMEN = OFF ; Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
CONFIG IESO = OFF ; Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
; CONFIG2L
CONFIG PWRT = OFF ; Power-up Timer Enable bit (PWRT disabled)
CONFIG BOREN = SBORDIS ; Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
CONFIG BORV = 18 ; Brown Out Reset Voltage bits (VBOR set to 1.8 V nominal)
; CONFIG2H
CONFIG WDTEN = ON ; Watchdog Timer Enable bit (WDT is always enabled. SWDTEN bit has no effect)
CONFIG WDTPS = 32768 ; Watchdog Timer Postscale Select bits (1:32768)
; CONFIG3H
CONFIG CCP2MX = PORTC ; CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
CONFIG PBADEN = ON ; PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
CONFIG LPT1OSC = OFF ; Low-Power Timer1 Oscillator Enable bit (Timer1 configured for higher power operation)
CONFIG HFOFST = ON ; HFINTOSC Fast Start-up (HFINTOSC starts clocking the CPU without waiting for the oscillator to stablize.)
CONFIG MCLRE = ON ; MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
; CONFIG4L
CONFIG STVREN = ON ; Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
CONFIG LVP = ON ; Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
CONFIG XINST = OFF ; Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
; CONFIG5L
CONFIG CP0 = OFF ; Code Protection Block 0 (Block 0 (000800-001FFFh) not code-protected)
CONFIG CP1 = OFF ; Code Protection Block 1 (Block 1 (002000-003FFFh) not code-protected)
CONFIG CP2 = OFF ; Code Protection Block 2 (Block 2 (004000-005FFFh) not code-protected)
CONFIG CP3 = OFF ; Code Protection Block 3 (Block 3 (006000-007FFFh) not code-protected)
; CONFIG5H
CONFIG CPB = OFF ; Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
CONFIG CPD = OFF ; Data EEPROM Code Protection bit (Data EEPROM not code-protected)
; CONFIG6L
CONFIG WRT0 = OFF ; Write Protection Block 0 (Block 0 (000800-001FFFh) not write-protected)
CONFIG WRT1 = OFF ; Write Protection Block 1 (Block 1 (002000-003FFFh) not write-protected)
CONFIG WRT2 = OFF ; Write Protection Block 2 (Block 2 (004000-005FFFh) not write-protected)
CONFIG WRT3 = OFF ; Write Protection Block 3 (Block 3 (006000-007FFFh) not write-protected)
; CONFIG6H
CONFIG WRTC = OFF ; Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
CONFIG WRTB = OFF ; Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
CONFIG WRTD = OFF ; Data EEPROM Write Protection bit (Data EEPROM not write-protected)
; CONFIG7L
CONFIG EBTR0 = OFF ; Table Read Protection Block 0 (Block 0 (000800-001FFFh) not protected from table reads executed in other blocks)
CONFIG EBTR1 = OFF ; Table Read Protection Block 1 (Block 1 (002000-003FFFh) not protected from table reads executed in other blocks)
CONFIG EBTR2 = OFF ; Table Read Protection Block 2 (Block 2 (004000-005FFFh) not protected from table reads executed in other blocks)
CONFIG EBTR3 = OFF ; Table Read Protection Block 3 (Block 3 (006000-007FFFh) not protected from table reads executed in other blocks)
; CONFIG7H
CONFIG EBTRB = OFF ; Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
;-------------reset vector----------------
org 0h
goto main
;--------------initialise ports and timer 2-------------
; clrf ANSEL
clrf TRISD
clrf PORTD
; clrf LATD
; Timer 2
clrf PIE1
clrf T2CON
clrf TMR2
clrf INTCON
clrf PIR1
bsf INTCON,PEIE ; Peripheral interrupt enable
bsf INTCON,GIE ; global interrupt enable
bsf PIE1,TMR2IE ; timer2 interrupt enable
;---------------set oscillator frequency to 4 MHz---
bsf OSCCON,6
bcf OSCCON,5
bsf OSCCON,4
;------------------main program---------------------
main
movlw b'11110000'
movwf PORTD
call delay
movlw b'00001111'
movwf PORTD
goto main
;--------------------timer 2 delay---------------------
delay
movlw d'127'
movwf T2CON
movlw d'6'
movwf PR2
bsf T2CON,TMR2ON
;do polling
wait
btfss PIR1,TMR2IF
goto wait
;overflow detected
bcf PIR1,TMR2IF
;return to main
return
;--------program end---------------------------------
end
