elvinng
Newbie level 1
Hi, all.. I am a newbie in PIC programming.. i nid help for project which require me to do ADC conversion from strain gauge sensors and analyse the signal..
Details: PIC18F4520, MPLAB, C programming code, datasheet..
note: i will use 2 sensors, so i nid to do assign 2 analog input..
MY questions: 1) any similar c programming code can be provided as example?
2) for 2 analog input, ADCON0 & ADCON1 both can assign analog
input, but how come i have select 1 channel in ADCON0 and i oso nid to select channel input in ADCON1??
3)Besides, from researching (the PIC18 can only convert one channel at a time.) so how should i do this if i apply force to both sensor?
3) after conversion, that is 10bits binary data rite? and how should i relate that to how much force i have applied to sensors?
//===============configuration==============================
;XTAL = 20MHz
#pragma config PLLDIV = 5 //This value has to be 5 for 20Mhz xtal as PLL accepts fixed input of 4MHz only
#pragma config OSC = HS, OSCS = OFF
#pragma config BORV = 45, PWRT = ON, BOR = ON
#pragma config WDT=off //disable Watchdog timer for resetting PIC
#pragma config DEBUG = OFF, LVP = OFF, STVR = OFF
#include <pic.h> //pic cpu header file
#include <18f4520.h>
#include <adc.h>
void Adc_Initial(void)
ADCON0 = 0x01; //channel 0(AN0), A/D module is enabled.
ADCON1 = 0x0B; //analog input: AN0-AN3, others digital I/O
TRISA = 0X0F; //make RA0-RA3 as sensor signal input
TRISB = 0X00; //make PORTB as output
ADCON2 = 0x8A; //Fosc/32, right justified, 2Tad
ADCON0bit.GO_DONE = 1; //start the conversion
Here is my code which have not yet done since i dunno how to move on, pls teach me !!! I am very nervous for this :? Appreciate much if this forum could help me..
Thank you in advance!!!!!!!!!!!
;XTAL = 20MHz
#include <adc.h>
