Suhas Anand
Junior Member level 2
- Joined
- Nov 1, 2014
- Messages
- 24
- Helped
- 5
- Reputation
- 10
- Reaction score
- 4
- Trophy points
- 3
- Activity points
- 151
Try "Tools" - "Use VPP first program entry" and retry to see if it helps.
You did not say what length your output wires are and if you have tried very short ones.
Also , as Veketti mentions, try the V2.61 Tools and run the Troubleshooting tests to check the voltages and signals to the actual pic pins; though just because the slow test signals get though does not mean that high speed programming pulses will work with long leads or bad connections.
Whos clone have you got, a bought one or a diy build ?
