[SOLVED] PIC18F25K22 + MikroC and JHD12864E(graphic LCD) problem
ltsharma
banglore
I bought a new JHD12864E graphic LCD and PIC18f25k22 microcontroller + 4MHZ crystal,
i used Mikroc's GLCD example with changing of Rx to LATx
and ANSEL to ANSELA/B/C for this PIC,
compiled perfectly, in Proteus running perfect (with AMPIRE 128X64)
When on hardware connection
problem is when GLCD's VCC pin is kept connected there is nothing on display. if i removed VCC pin of GLCD for some seconds and connect back, it shows received data on display for few seconds and one side vanishes, again its not receives any new signals (data), have to disconnect and connect VCC back.
(Watch with caption)
Change this
Code C - [expand]
char GLCD_DataPort at PORTC;
to
Code C - [expand]
char GLCD_DataPort at LATC;
and see. If doesn't work then add
Code C - [expand]
TRISB = 0x00; TRISC = 0x00;
I don't have Proteus 8. so, post proteus 7.x format file. GLCD maybe defective. Try with another GLCD.
i did what u said,
output is
Proteus o/p
hardware o/p
Proteus 7 dont having pic18f18k22
no change,
same result
HEYYYY...
i put image its came perfect
FOSC means Config bits?
used 4mhz crystal with no pll
and another one, if i did
Proteus output is good, but not works on hardware
WOHHHHHHHHHHHH its worked in hardware also,,,,
ONLY the small silly problem since,
needed to put
THANX a lot jayanth, im struggling from last one month,
SORRY for disturbing you peoples
jayanth.devarayanadurga & tpetar
  • GLCD test.rar
Hello ,
Form where do you get this section
const code char arun[1024] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 7, 63, 248, 193, 63, 31, 249, 192, 61, 3, 1, 255, 255, 17, 57, 1, 131, 1, 255, 255, 1, 0, 128, 192, 0, 124, 254, 131, 1, 1, 2, 135, 0, 0, 124, 254, 131, 1, 1, 131, 254, 124, 0, 1, 255, 15, 126, 248, 192, 56, 7, 255, 255, 1, 1, 255, 255, 17, 57, 1, 131, 0, 206, 159, 25, 49, 242, 231, 0, 0, 0, 0, 1, 7, 31, 248, 224, 25, 7, 1, 0, 124, 254, 131, 1, 1, 131, 254, 124, 0, 1, 255, 255, 1, 0, 1, 255, 1, 0, 143, 191, 0, 0, 143, 191, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 1, 1, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 1, 1, 1, 0, 1, 193, 224, 225, 225, 193, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 1, 1, 0, 0, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 192, 240, 252, 255, 255, 127, 31, 127, 255, 255, 252, 240, 192, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 112, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 252, 255, 255, 127, 31, 7, 1, 0, 0, 0, 1, 7, 31, 127, 127, 255, 252, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 248, 112, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 3, 3, 7, 7, 15, 15, 31, 31, 63, 62, 126, 252, 252, 248, 248, 240, 96, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 96, 240, 248, 248, 252, 252, 126, 62, 63, 31, 31, 15, 15, 7, 7, 3, 3, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 128, 224, 252, 255, 255, 255, 255, 207, 225, 224, 224, 240, 240, 248, 248, 252, 124, 126, 62, 126, 124, 252, 248, 248, 240, 240, 240, 224, 225, 199, 255, 255, 255, 255, 252, 224, 128, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 30, 63, 63, 63, 31, 31, 15, 15, 7, 7, 3, 3, 3, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 3, 3, 3, 7, 7, 15, 15, 31, 31, 63, 63, 63, 30, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
