PIC18F dividing in assembly language
Raju C
Member level 2
Bangalore
PIC18F assembly
Hi all..
can anybody tell me how to do the program for INT(3E85h/1024) in assembly , i am using PIC18F and here no division operation so pls can any one help .. how to write code ?
Re: PIC18F assembly
ya i got .. whether i can use RRf in program directly ? their is no instruction such ?
Re: PIC18F assembly
hi,
RRF on the 16F
RRCF or RRNCF on the 18F
PIC18F assembly
ya correct .. RRCF in 18F but .. if you use this you wont get the result for all no's .. see 3E85 and 3F4d you check this operation on both output should be 15 but we wont get that..
Re: PIC18F assembly
Thats because you are not clearing the carry while looping back.
Try this code.
movlw 3Fh
movwf msb
movlw 4Dh
movwf lsb
movlw .10
movwf counter
loop bcf status,carry ; carry is cleared while looping back
rrcf msb,same
rrcf lsb,same
decfsz counter,same
goto loop
Cheers
Ravi
PIC18F assembly
same means here you are telling two times shift ?after shifting msb i need to clear carry .. and again after shifting lsb also i have to clear carry ??
Re: PIC18F assembly
same = 1, means save it back in the same register. ex:- rrf msb,1.
Before shifting MSB, clear the carry, any carry from MSB has to be shifted into LSB. So for the next looping, clear the carry if any from LSB as we do not need it.
Cheers
Ravi
PIC18F assembly
ya 1 means it will store to same reg , i will try this and if i get any prob i will ask you ..
Re: PIC18F assembly
WRITIN SOFTWARE IS NT A JOKE.
Re: PIC18F assembly
ya its not a joke ??
Added after 2 hours 31 minutes:
Cheers
Ravi
i tried it but after shifting 10 times we will get 1F and 26 in MSB and in LSB respectively.. but the result should be F so where it will be??
Use the simulator MPSIM and you could see how things develope.
Go slowly and be strict in the checking of what you do.
