PIC18F and PWM problem
trastikata
I am trying to implement a PWM on a PIC18F6585. After setting up the PWM registers I get to control the PWM Period and PWM Duty Cycle successfully.
    'PWM_SETUP
    TRISC.2 = 1         'Configure P1A as input
    PR2 = 12            'Set PWM period to 2 uS / 500kHz
    CCP1CON = %00001100 'Single PWM output P1A - active high
    CCPR1L = 6          'Set PWM duty cycle to 50%
    TMR2IF = 0          'Clear Timer2 Interrupt Flag
    T2CON = 0           'Timer2 prescaller 1:1
    T2CON.2 = 1         'Start Timer2
    DelayCS 13          'Wait 13 cycles for Timer2 to overflow
    TRISC.2 = 0         'Configure P1A As Output
    ECCP1AS = 0         'Clear ECCPASE bit
    'Do something else
However when I checked with an oscilloscope it looks like that besides the main PWM frequency of 500kHz there is another lower frequency switching on and off the PWM. The following 2 pictures show the same signal - the normal 500kHz output and the 26Hz on-off of the PWM pin. Any idea what is causing it?
Thank you
We need to see the full code to be sure but as a guess I would say you have the watchdog timer enabled and are not resetting it. The result would be the IC shutting down and resetting in a loop.
Thank you Brian.
The first thing I tested was to see if the PIC is resetting by using another pin held high - the PIC is not resetting. Also the watchdog is disabled.
What I find strange is that increasing the PWM frequency over 500kHz (lowering the PR2 value below 12) removes the issue - P1A pin (PORTC.2) is not toggling between on-off.
The full code is the following:
Device = 18F6585
Config_Start
    OSC = HS	;HS oscillator
    OSCS = OFF	;Oscillator system clock switch option is disabled (main oscillator is source)
    PWRT = On	;PWRT enabled
    BOR = On	;Brown-out Reset enabled
    BORV = 27	;VBOR set to 2.7V
    WDT = OFF	;WDT disabled (control is placed on the SWDTEN bit)
    WDTPS = 32768	;1:32768
    CCP2MX = On	;CCP2 input/output is multiplexed with RC1
    MCLRE = On	;MCLR pin enabled, RG5 input pin disabled
    STVR = On	;Stack full/underflow will cause Reset
    LVP = OFF	;Low-voltage ICSP disabled
    Debug = OFF	;Background debugger disabled. RB6 and RB7 configured as general purpose I/O pins.
    Cp0 = OFF	;Block 0 (000800-003FFFh) not code-protected
    CP1 = OFF	;Block 1 (004000-007FFFh) not code-protected
    CP2 = OFF	;Block 2 (008000-00BFFFh) not code-protected
    CPB = OFF	;Boot block (000000-0007FFh) not code-protected
    CPD = OFF	;Data EEPROM not code-protected
    WRT0 = OFF	;Block 0 (000800-003FFFh) not write-protected
    WRT1 = OFF	;Block 1 (004000-007FFFh) not write-protected
    WRT2 = OFF	;Block 2 (008000-00BFFFh) not write-protected
    WRTC = OFF	;Configuration registers (300000-3000FFh) not write-protected
    WRTB = OFF	;Boot block (000000-0007FFh) not write-protected
    WRTD = OFF	;Data EEPROM not write-protected
    EBTR0 = OFF	;Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
    EBTR1 = OFF	;Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
    EBTR2 = OFF	;Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
    EBTRB = OFF	;Boot block (000000-0007FFh) not protected from table reads executed in other blocks
Config_End
Xtal = 26               'Use 26MHz crystal
    'PWM_SETUP
    PIR1.1 = 0          'Clear Timer2 Interrupt Flag
    While 1 = 1 : Wend  'Do something else - empty loop
My idea:
It's a measurement problem - and no real problem.
It is called "alias frequency" when the sampling rate is less than double of your signal frequency.
--> read about "sampling theorem" and "Nyquist".
