pic16f88 not working properly
amitaiwe
Member level 3
Member level 3
I want to implement a project using the PIC16F88.
As a start and for needed indications later a want to lit up a led
and it doesn't work properly
I'm using a PICKIT3 for programing, and I have managed to program a PIC16F877
for another program.
I tried various variations of turning on/off and flickering led commands.
In all the cases the led (bi-colored) responded after a long time (~30 sec)
and turned off and on randomly. The mplab software messages inform
of no errors and of successful programing.
The led works well when not connected to the PIC.
What can the problem by?
I'm attaching the recent code
Thanks, Amitai
LIST	P=PIC16F88
include	<P16f88.inc>
org		0x00
	__CONFIG _CONFIG1, _LVP_OFF &_WDT_OFF &_PWRTE_OFF &_CP_OFF & _INTRC_IO
	reset:
	nop
	goto	start
	org		0x20
start:
; CONFIGURATION*-*-*-*-*-*-*-*-*-
; used_ registers:
	MUX_sel			EQU H'0021'  		; MUX select value
	del1			EQU H'0030'  		; for delay
	del2			EQU H'0031'  		; for delay
	to_transmit		EQU H'0050'  		; data register
	led1			EQU H'0070'  		; for led delay
	demo_tr			EQU H'0072'  		; demo transmit
	loop_mux		EQU H'0074'  		; demo transmit
; oscillator
	banksel		OSCCON					; 8M internal clk, mode defined
	movlw		0b01110100					; by fosc(2:0), ??????
	movwf		OSCCON					; system clock source from main oscillator
; led
	BANKSEL 	PORTB ; select bank of PORTA
	CLRF		PORTB ; Initialize PORTA by
	banksel		ANSEL					; Configure all pins as digital inputs
	clrf		ANSEL
	banksel		TRISB
	clrf		TRISB					; make PORTB output
; MAIN PROGRAM*-*-*-*-*-*-*-*-*-*
Led_flicker:
	banksel		PORTB
	bsf			PORTB,3
	bcf			PORTB,2
;---end Led flicker
; END MAIN PROGRAM*-*-*-*-*-*-*-*-*-*
end
I have no idea what you are trying to do here. You set bit 3 of portb, then you clear bit 2 of portb and then I think your program just runs off into the woods.
I'm aware of that. As I wrote, I have done a few test with different
options for the led and non of them changed.
I can reverse one of the versions:
LIST	P=PIC16F88
org		0x00
	reset:
	nop
	goto	start
	org		0x20
start:
; used_ registers:
; oscillator
; led
	clrf		ANSEL
	banksel		TRISB
Led_flicker:
	banksel		PORTB
	bsf			PORTB,3
	bcf			PORTB,2
        CALL                 DELAY
        bsf			PORTB,2
	bcf			PORTB,3
        goto                  Led_flicker
;---end Led flicker
DELAY:
	movlw		0xFF
	movwf		del1
	movlw		0xFF
	movwf		del2
	loopa:
	decfsz		del1, f
	goto		loopa
	loopb:
	decfsz		del2, f
	goto		loopb
	return
end
Amitai
Your code put back in to order with a Delay routine - you should be able to follow things from the comments I have added.
The picture shows the program running, you just need to add Vdd and Vss to your chip and it should work.
These tutorials should help you do more ..
http://www.winpicprog.co.uk/pic_tutorial.htm
http://www.amqrp.org/elmer160/lessons/
http://www.epemag.wimborne.co.uk/resources.htm
	LIST	P=PIC16F88
	org		0x00
	__CONFIG _CONFIG1, _LVP_OFF &_WDT_OFF &_PWRTE_OFF &_CP_OFF & _INTRC_IO & _MCLRE_OFF
; user_ registers:
	cblock 0x20
	MUX_sel		  		; MUX select value
	del1		 		; for delay
	del2				; for delay
	to_transmit			; data register
	led1		 		; for led delay
	demo_tr				; demo transmit
	loop_mux			; demo transmit
	d1,d2,d3			; delay work files
	endc
reset:
	nop
	goto	start
	org		0x20
start:
; oscillator				; 8M internal clk, mode defined
	movlw		b'01110100'
; led
	clrf		ANSEL
	banksel		TRISB
Led_flicker:							; FLASH A LED ON AND OFF RB3
	banksel		PORTB
	bsf			PORTB,3					; turn on led
	call		delay500ms				; delay 1/2 second
	bcf			PORTB,3
	goto		Led_flicker				; return to start of the loop
;---end Led flicker
; SUB ROUTINES*-*-*-*-*-*-*-*-*-*
delay500ms								; based on 8mhz oscillator
	movlw	0x08
	movwf	d1
	movlw	0x2F
	movwf	d2
	movlw	0x03
	movwf	d3
Delay_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	$+2
	decfsz	d3, f
	goto	Delay_0
    return
end
I still don't understand what you're doing with those two port pins. Why are you toggling two pins? Maybe we need to see your schematic.
Like you say he needs to explain the parts he is actually using plus a schematic.
Assume he is trying to do as the pics show, but I just gave him the working single flasher code so he could hopefully progress further himself.
