Hi
I have PIC16F877A microcontroller and i want to program it, i have found many designs on the Internet for Programmers which can be used to program it, but i donot know if they are trusted or not.
Can you recomend me a Programmer which is easy to build and working proberly and i prefer if you have tested it by your self.
Best Regards.
thank you but I want the PIC16F877A programmer, the programmer you suggested only fit the PIC 84A, so if you have any 877A programmer, they would be very useful.
Hi, yes blueroomelectronics, that is true,
but our colege mr_anderson use 877 and probably (until now) don't have any pic programmer, that lousy JDM style programmer is good solution for him for a little money and 877 class,
best regards
Hai Anderson
You may try building Junebug from Blueroom electronics whose schematic is attached here, or get a cute tiny programmer for PIC devices, available from **broken link removed**
I am using the above programmer for programming 16f877A, You can use winpic800 as software for the programmer. I have made more than 10 such programmers for my friends and all are using with 16f877A, 16f88
