PIC16F877A has a hardware IIC interface,you shoule set relative register in order,or you use bleow codework in 4MHZ)
;************************************************************************* ;PAGE3 (600-6FF)
;PAGE3 (600-6FF)
; ;PAGE3 (600-6FF)
;***************************************************************************** ;PAGE3 (600-6FF)
;** Two wire/I2C Bus READ/WRITE Routines of Microchip's ;PAGE3 (600-6FF)
;** 24LCXX / 85Cxx serial CMOS EEPROM interfacing to a ;PAGE3 (600-6FF)
;** PIC16C57 8-bit CMOS single chip microcomputer ;PAGE3 (600-6FF)
;** Revsied Version 2.0
;** ;PAGE3 (600-6FF)
;** Part use = PIC16F57
;** Note: 1) All timings are based on a reference crystal frequency of 4MHz ;PAGE3 (600-6FF)
;** which is equivalent to an instruction cycle time of 1 usec. ;PAGE3 (600-6FF)
;** 2) Address and literal values are read in octal unless otherwise ;PAGE3 (600-6FF)
;** specified.
;----------------------------------------------------------------------------- ;PAGE3 (600-6FF)
; Two wire/I2C - CPU communication error status table and subroutine
; input : W-reg = error code ;PAGE3 (600-6FF)
; output : ERCODE = error code ;PAGE3 (600-6FF)
; FLAG(ERROR) = 1 ;PAGE3 (600-6FF)
; code error status mode ;PAGE3 (600-6FF)
; ------- ------------------------------------------------------ ;PAGE3 (600-6FF)
; 1 : 3 locked low by device (bus is still busy) ;PAGE3 (600-6FF)
; 2 : 4 locked low by device (bus is still busy) ;PAGE3 (600-6FF)
; 3 : No acknowledge from device (no handshake) ;PAGE3 (600-6FF)
; 4 : 4 bus not released for master to generate STOP bit ;PAGE3 (600-6FF)
;Subroutine to identify the status of the serial clock (3) and serial data ;PAGE3 (600-6FF)
;(4) condition according to the error status table. Codes generated are ;PAGE3 (600-6FF)
;useful for bus/device diagnosis.
; START bus communication routine
; input : none
; output : initialize bus communication
; Time Used: MMAX 23 Cycle.
;Generate START bit (3 is high while 4 goes from high to low transition) ;PAGE3 (600-6FF)
;and check status of the serial clock.
BSTART
MOVLW B'00000001' ; Put 1,2 line in output state ;PAGE3 (600-6FF)
TRIS PORTB ;PAGE3 (600-6FF)
BSF IIC_SDA ;Make data line is high level
; NOP ;PAGE3 (600-6FF)
BCF IIC_SCL ;Make clock line is low level
NOP
BSF IIC_SCL ; Make clock line is 1
; NOP
BCF IIC_SDA ; make data lin got 0 from 1 when clock=1
BSF IIC_SDA ; Make data line 1 from 0 when clock line = 1
BCF IIC_SCL ; Make clock line low
NOP
RETLW .0 ;PAGE3 (600-6FF)
; Serial data send from PIC to serial EEPROM, bit-by-bit subroutine ;PAGE3 (600-6FF)
; Input : None
; Output : To (DI) of serial EEPROM device ;PAGE3 (600-6FF)
; Time Used: MAX 17 Cycle.
BITIN
BSF EEPROM,DI ; In case of input data = 1
MOVLW B'10000001' ; Force SDA line as input ;PAGE3 (600-6FF)
; Serial data receive from serial EEPROM to PIC, bit-by-bit subroutine
; Input : EEPROM file
; Output : From (DO) of serial EEPROM device to PIC
; Time Used: MAX 13 Cycle.
BITOUT
BTFSS EEPROM,DO ; Check the status of sending data ;PAGE3 (600-6FF)
GOTO BIT0 ; =0 ;PAGE3 (600-6FF)
BSF IIC_SDA ; =1 ;PAGE3 (600-6FF)
GOTO CLKOUT
