pic16f877a+adc using interrupt+hitech c
manikandanshine
Full Member level 1
Full Member level 1
india
in my project i want to use analog to digital conversion using ADIF Interrupt.......i am using hitech c compiler......if anybody knows plz help me.....thanks in advance.....
For a thorough explanation of the ADC of the PIC16F877A with examples, go through these:
Modalities Of Using The ADC Module Of PIC 16F877A
https://www.edaboard.com/blog/1569/
https://www.edaboard.com/blog/1570/
https://www.edaboard.com/blog/1571/
https://www.edaboard.com/blog/1572/
https://www.edaboard.com/blog/1573/
https://www.edaboard.com/blog/1574/
While the example codes are in mikroC, it should be quite easy to port the codes to Hi-Tech C once you understand everything.
Hope this helps.
Tahmid.
for a thorough explanation of the adc of the pic16f877a with examples, go through these:
modalities of using the adc module of pic 16f877a
while the example codes are in mikroc, it should be quite easy to port the codes to hi-tech c once you understand everything.
Hope this helps.
Tahmid.
nice tutorials tahmid sir.....but i want without using godone bit how to do analog to digital conversion......thanks for ur reply.......
Hope this helps.
Tahmid.
NICE TUTORIALS TAHMID SIR.....BUT I WANT WITHOUT USING GODONE BIT HOW TO DO ANALOG TO DIGITAL CONVERSION......THANKS FOR UR REPLY.......
