PIC16F877A A/D conversion problem
RATAN ROY
Junior Member level 1
Kolkata,West bengal,India
Hi Everybody,
I m a new user of microcontroler (PIC16F877A). I will have to perform an a/d conversion n will have to display the corresponding analog value with the help of seven segment display.but i got the converted result from 10bit inbuilt ADC,but my controller is 8bit.After this how can i go ahead?? i m finding nothing from myself.If anybody can help me,plz......
I wd like to start embedded C also. for this what should i follow,anybook...plz
your 10 bit ADC result is stored in two registers ADRESL(8 LSB) and ADRESH(2 MSB) so
<ADRESH:ADRESL> comprises of 16 bit of data which contains 10 LSB of ADC write a program which store two bytes in one 16 bit word
Reactions: ashref
    ashref
Hai
How many seven segment digit you have interfaced in your hardware?
I thing you need 4 Nos.
What Mr.Saeed saying is correct. Since you are doing in C, Use shift operator << and concatenate these two registers. Then simply do for hexadecimal to decimal conversion store the result in 4 variable. The hexadecimal range for the ADC output will be 000H --3FFH
If you convert into decimal, it is maximum of 1023(3FFH). So totally 4 digits.The stored 4 variables content are despatched to each corresponding 7 segment display.
Hi..........
thnx for ur rply to me.bt i m confused where i will keep the 16bit word(L+H) in PIC16F877A from where i'll take 10LSB n hw will i convert hex to original analog voltage in assembly language which is going to display by 7-segment display.Can u help me by sending any example code for the same.......Plz
I m looking frwrd 4 ur positive rply......
There is a simulation software called PROTEUS. If you have it then you can find the sample code with circuit design for the ADC of PIC you want.
Regards,
Jerin.
There are also samples in C compilers. If you are using one of them =)
You can find the sample programs in MikroC compiler(compiler in C) as said by john & also various library functions are also available there to do the same operation with simple functions.
Regards,
Jerin.
