Open the datasheet of PIC16F84,
Arrange a breadboard and components,
Give VCC and VSS to pins mentioned there,
Connect a 4 mhz Xtal to osc1 and osc2 pins
Connect 2 22Pf caps from OSC1 And OSC2 to GND.
Connect A led + to RB0 (Datasheet) and Connect the other pin of led to gnd through 330 ohm resistor.
Now open MPLAB ,write a small programe to light or flash pin RB0 led.
Construct a simple JDM or similer programmer and programe and test this pic.
All the best
Picstudent
thanks, but i still have one more question :
i want to start any project using pic16f84a, i have some projects for the 16f84 (without A) . can the 16f84a work with the same code ?
Regards,
thanks gidimiz, i appreciate your help .
shall i program the 16f84a directly without changing the configurations ( oscillator,WDT,PWRT or CP ) ?
regards,
regards,
