PIC16F676 substitute required using in 90V to 290V AC 5 step staiblizer
If you have the source code then you can almost use any similar 16F chip you can find locally, but you will probably have to amend the odd parameter.
Seems that chip is readily available from all the big suppliers and loads on ebay, might be easier to get the same chip....
Dear All, can anyone help me fo substitute IC in place of PIC16F676 ( i am currently using in 90V to 290V AC 5 step staiblizer ) as now a days it is out of market in our city.
If you have source file, upload it or send and we will convert it to microcontroller commonly available in market.
I will reply you soon after modification. Modification to hex file will take time. If u have c code, the modification will take just 5 to 10 minutes
