seyyah
Advanced Member level 2
pic16f628 comparator
If we configure CM2:CM0=010 (The configuration that we use two comparators, one input of each comparator is from vref module and the selection between RA0 - RA3 and RA1 - RA2 is done by CMCON[CIS])
Say we only want to use RA1 as analog input to comparator and we made other pins output by setting necessary bits in TRISA register. What i want to ask is: In this configuration, if we set RA0,RA2 and RA3 pins as out, can we use them as digital output? Or can we only use as analog inputs?
