BlackOps
Full Member level 5
- Joined
- Jan 1, 2005
- Messages
- 280
- Helped
- 14
- Reputation
- 28
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- AZERBAIJAN
- Activity points
- 2,496
16c74b pclath
i am trying to make Microchip AN582 appnote work in PROTEUS. The code for AN582 is written for PIC16C74, but i have model in proteus only for PIC16C74B.
code compiled good in MPLAB 7.60, but when i assembled Circuit in PROTEUS. and did run that code, all pins of the PIC were in grey color! seems like no ports were set to input or output... and the circuit didnt work.. i wonder why?
i did read the PIC16C74A to PIC16C74B migration manual! and they write that Reading or writing TMR1H or TMR1L may affect TMR1H or TMR1L
unexpectedly. everything else looks ok... but what do i miss then?
did anyone worked with these PICs?
here is the code maybe u will spot something:
Added after 1 hours 10 minutes:
PROTEUS also shows CPU load of 0%
seems like it is not working at all...
i did change PIC16C74 to PIC16C74B in the beginning of program, what other changes should i do?
LIST P = 16C74B, n = 66
ERRORLEVEL -302
; This program implements a real time clock using the TMR1 module of the
; PIC16Cxx family. A LCD display module is used to display (update) the time
; every second. Three keys are used to set the time.
; Program = CLOCK.ASM
; Revision Date: 5-15-94
; 1-15-97 Compatibility with MPASMWIN 1.40
; HARDWARE SETUP
; LCD Control Lines
; RA0 = E (Enable)
; RA1 = RW (Read/Write)
; RA2 = RS (Register Select)
; LCD Data Lines
; RB<3:0>
; Switch Inputs
; RB7 = Select Hour / Minute / Off
; RB6 = Increment Hour / Minute
; RB5 = Reset Minutes to 00
INCLUDE <p16c74B.inc>
FALSE EQU 0
TRUE EQU 1
INCLUDE <CLOCK.h>
LCD_DATA EQU PORTB ; The LCD data is on the lower 4-bits
LCD_DATA_TRIS EQU TRISB ; The TRIS register for the LCD data
LCD_CNTL EQU PORTA ; Three control lines
PICMaster EQU FALSE ; A Debugging Flag
Debug EQU FALSE ; A Debugging Flag
Debug_PU EQU TRUE ; A Debugging Flag
; Reset address. Determine type of RESET
org RESET_V ; RESET vector location
RESET BSF STATUS, RP0 ; Bank 1
BTFSC PCON, NOT_POR ; Power-up reset?
GOTO START ; YES
GOTO OTHER_RESET ; NO, a WDT or MCLR reset
; This is the Periperal Interrupt routine. Need to determine the type
; of interrupt that occurred. The following interrupts are enabled:
; 1. PORTB Change (RBIF)
; 2. TMR1 Overflow Interrupt (T1IF)
page
org ISR_V ; Interrupt vector location
PER_INT_V
if ( Debug )
bsf PORTD, 0 ; Set high, use to measure total
endif ; time in Int Service Routine
BCF STATUS, RP0 ; Bank 0
BTFSC PIR1, TMR1IF ; Timer 1 overflowed?
GOTO T1_OVRFL ; YES, Service the Timer1 Overflow Interrupt
BTFSS INTCON, RBIF ; NO, Did PORTB change?
GOTO ERROR1 ; NO, Error Condition - Unknown Interrupt
PORTB_FLAG ; Are any of PORTB's inputs active?
MOVF PORTB, W ;
ANDLW 0xE0 ; Keep only the 3 switch values
DEBOUNCE MOVWF TEMP ;
MOVLW DB_HI_BYTE ; This is the debounce delay
MOVF MSD, F ;
CLRF LSD ;
KB_D_LP1 DECFSZ LSD, F ;
GOTO KB_D_LP1 ;
DECFSZ MSD, F ;
GOTO KB_D_LP1 ;
END_DELAY MOVF PORTB, W ;
SUBWF TEMP, F ;
BTFSS STATUS, Z ; Is the Zero bit set?
; (switches were the same on 2 reads)
GOTO DEBOUNCE ; NO, Try another read
KEY_MATCH MOVWF TEMP ; YES, need to see which is depressed.
MOVLW 0x80 ; Since doing key inputs, clear TMR1
MOVWF TMR1H ; for 1 sec overflow.
CLRF TMR1L ;
BCF PIR1, TMR1IF ; Clear Timer 1 Interrupt Flag
BTFSS TEMP, HR_MIN_SW ; Is the hour-min-off switch depressed?
GOTO SELECT_UNITS ; YES, specify the units selected
BTFSS TEMP, INC_SW ; Is the inc switch depressed?
GOTO INC_UNIT ; YES, Increment the selected Units
BTFSS TEMP, CLR_MIN_SW ; Is the clear minute switch depressed?
GOTO CLR_MIN ; YES, clear the minutes.
; No key match occured, or finished with PortB interrupt and need to clear interrupt condition.
CLR_RB ; No RB<7:5> keys are depressed (rising edge Int.)
MOVF PORTB, F ; Clear the PORTB mismatch condition
BCF INTCON, RBIF ; Clear the PORTB Int Flag
if ( Debug )
bcf PORTD, 0 ; Set low, use to measure total
endif
RETFIE ; Return / Enable Global Interrupts
page
SELECT_UNITS
MOVLW 0xFF ;
MOVWF WAIT_CNTR ; WAIT_CNTR has LSb set after each SELECT UNIT key press.
INCF FLAG_REG, F ; Increment the pointer to the MIN_UNIT:HR_UNIT
BSF FLAG_REG, KEY_INPUT ;
GOTO DISPLAY ; Flash the Display of the selected unit
INC_UNIT
CLRF WAIT_CNTR ; WAIT_CNTR is cleared to zero after each key press.
BTFSC FLAG_REG, HR_UNIT ; Are the hour units selected?
GOTO INC_HRS ; YES, Increment the hour units
BTFSS FLAG_REG, MIN_UNIT ; Are the minute units selected?
GOTO CLR_RB ; NO, Not a valid key. Clear flags
INCF MIN, F ; YES, Increment the minute units
MOVLW 0x3C ; This is Decimal 60
SUBWF MIN, W ; MIN - 60 = ?
BTFSS STATUS, Z ; MIN = 60?
GOTO DISPLAY ; NO, display time
; YES, MIN = 0 (use code from CLR_MIN)
CLR_MIN CLRF MIN ; MIN = 0
MOVLW 0x04 ; Clear the seconds
MOVWF SECS ; Initial Second count = 4
MOVLW 0x80 ; Clear Timer 1, for 1 sec overflow
MOVWF TMR1H ;
CLRF TMR1L ;
BCF PIR1, TMR1IF ; Clear the TMR1 overflow interrupt.
BTFSC TEMP, CLR_MIN_SW ; Is the clear minute switch depressed?
GOTO DISPLAY ; NO. Rollover from increment key
BCF FLAG_REG, MIN_UNIT ; YES, Clear ALL relevant flags
BCF FLAG_REG, HR_UNIT ;
BCF FLAG_REG, KEY_INPUT ;
GOTO DISPLAY ;
page
T1_OVRFL
BTFSS FLAG_REG, KEY_INPUT ; Are we using the key inputs?
GOTO INC_TIME ; NO, Need to Increment the time
INCF WAIT_CNTR, F ; YES,
MOVLW 0x0A ; 10 counts x 1 seconds
SUBWF WAIT_CNTR, W ; Has the 10 Sec wait for key expired?
BTFSS STATUS, Z ; Is the result 0?
GOTO DISPLAY ; NO, Display value
CLRF WAIT_CNTR ; YES, Clear WAIT_CNTR
INC_TIME MOVLW 0x80 ;
MOVWF TMR1H ; 1 Second Overflow
INCF SECS, F ;
BTFSS SECS, 6 ;
GOTO DISPLAY ;
MOVLW 0x04 ;
MOVWF SECS ;
INCF MIN, F ;
MOVLW 0x3C ; W = 60d
SUBWF MIN, W ;
BTFSS STATUS, Z ;
GOTO DISPLAY ;
CLRF MIN ;
INC_HRS INCF HRS, F ;
MOVLW 0x0C ; It is now 12:00, Toggle AM / PM
SUBWF HRS, W ;
BTFSS STATUS, Z ;
GOTO CK_13 ; Need to check if HRS = 13
BTFSS FLAG_REG, AM ; Was it AM or PM
GOTO SET_AM ; Was PM, Needs to be AM
BCF FLAG_REG, AM ; It is PM
GOTO DISPLAY ;
SET_AM BSF FLAG_REG, AM ; It is AM
GOTO DISPLAY ;
CK_13 MOVLW 0x0D ; Check if HRS = 13
SUBWF HRS, W ;
BTFSS STATUS, Z ;
GOTO DISPLAY ;
CLRF HRS ;
INCF HRS, F ;
GOTO DISPLAY ;
page
INIT_DISPLAY
MOVLW DISP_ON ; Display On, Cursor On
CALL SEND_CMD ; Send This command to the Display Module
MOVLW CLR_DISP ; Clear the Display
MOVLW ENTRY_INC ; Set Entry Mode Inc., No shift
RETURN
DISPLAY
MOVLW DD_RAM_ADDR ;
CALL SEND_CMD ;
BTFSC FLAG_REG, KEY_INPUT ; Do we need to flash the selectected units?
GOTO FLASH_UNITS ; YES, we need to flash selected units
CALL LOAD_HRS ; NO, do a normal display
CALL LOAD_COLON ;
CALL LOAD_MIN ;
GOTO LOAD_AM ;
FLASH_UNITS
CLRF PCLATH ; This clears PCLATH, This table in 1st
MOVF FLAG_REG, W ; 256 bytes of program memory
ANDLW 0x03 ; only HR_UNIT and MIN_UNIT bit can be non-zero
UNIT_TBL
ADDWF PCL, F ; HR_UNIT:MIN_UNIT
GOTO NO_UNITS ; 0 0 - Display everything.
GOTO HR_UNITS ; 0 1 - Flash the hour units
GOTO MIN_UNITS ; 1 0 - Flash the minute units
UNIT_TBL_END
MOVLW 0xFC ; 1 1 - Need to clear FLAG_REG<HR_UNIT:MIN_UNIT>
ANDWF FLAG_REG, F ;
if ( (UNIT_TBL & 0x0FF) >= (UNIT_TBL_END & 0x0FF) )
MESSG "Warning: Table UNIT_TBL crosses page boundry in computed jump"
endif
HR_UNITS
BTFSS WAIT_CNTR, 0 ; If WAIT_CNTR is odd,
; hour digits are displayed as blank
GOTO SKIP_BLK_HRS ;
MOVLW ' ' ;
CALL SEND_CHAR ;
MOVLW ' ' ;
CALL SEND_CHAR ;
SKIP_BLK_HRS
BTFSS WAIT_CNTR, 0 ; WAIT_CNTR was even, display hour digits
CALL LOAD_HRS ;
MOVLW ':' ; : always on, display all other character
CALL SEND_CHAR ;
CALL LOAD_MIN ;
GOTO LOAD_AM ;
page
MIN_UNITS
CALL LOAD_HRS ; Display hours
CALL SEND_CHAR ;
; minute digits are displayed as blank
GOTO SKIP_BLK_MIN ;
MOVLW ' ' ;
CALL SEND_CHAR ;
MOVLW ' ' ;
CALL SEND_CHAR ;
SKIP_BLK_MIN
BTFSS WAIT_CNTR, 0 ; WAIT_CNTR was even, display minute digits
CALL LOAD_MIN ;
GOTO LOAD_AM ;
NO_UNITS
CALL LOAD_HRS ; Display all character
MOVLW ':' ;
CALL SEND_CHAR ;
CALL LOAD_MIN ;
GOTO LOAD_AM ;
LOAD_HRS
MOVF HRS, W ; Load the Wreg with the value
CALL BIN_2_BCD ; to convert to BCD
MOVF MSD, W ; Load the MSD value into the Wreg
CALL NUM_TABLE ; Get the ASCII code
CALL SEND_CHAR ; Send this Character to the Display
MOVF LSD, W ; Load the LSD value into the Wreg
RETURN
LOAD_COLON MOVLW ' ' ; ASCII value for a Blank space
BTFSC SECS, 0 ; Is it an EVEN or ODD second
ADDLW ':' - ' ' ; Is ODD, Second colon is ON.
; Add delta offset of ASCII Characters
RETURN
LOAD_MIN
MOVF MIN, W ; Load the Wreg with the value
RETURN
page
LOAD_AM MOVLW ' ' ; ASCII value for a Blank space
MOVLW 'A' ; ASCII value for a Blank space
BTFSS FLAG_REG, AM ; Is it AM or PM
ADDLW 'P' - 'A' ; Is PM, Add delta offset of ASCII Characters
MOVLW 'M'
BCF OPTION_REG, NOT_RBPU ; Turn on PORTB Pull-up
GOTO CLR_RB ; You've displayed the time, Clear RBIF
; The BIN_2_BCD routine converts the binary number, in the W register, to a
; binary coded decimal (BCD) munber. This BCD number is stored MSD:LSD. This
; routine is used by the DISPLAY subroutine, to convert the time values.
BIN_2_BCD CLRF MSD ; This value contain the 10's digit value
MOVWF LSD ; This value contain the 1's digit value
TENS_SUB MOVLW .10 ; A decimal 10
SUBWF LSD, W ;
BTFSS STATUS, C ; Did this subtract cause a Negative Result?
RETLW 0 ; YES, Return from this Routine
MOVWF LSD ; No, move the result into LSD
INCF MSD, F ; Increment the most significat digit
GOTO TENS_SUB ;
; Should NEVER get here
ERROR1 BCF STATUS, RP0 ; Bank 0
if ( Debug )
BSF PORTD, 1
BCF PORTD, 1
else
BSF PORTC, 0
BCF PORTC, 0
endif
GOTO ERROR1
page
;* SendChar - Sends character to LCD *
;* This routine splits the character into the upper and lower *
;* nibbles and sends them to the LCD, upper nibble first. *
;* The data is transmitted on the PORT<3:0> pins *
SEND_CHAR
MOVWF CHAR ; Character to be sent is in W
CALL BUSY_CHECK ; Wait for LCD to be ready
SWAPF CHAR, W
ANDLW 0x0F ; Get upper nibble
MOVWF LCD_DATA ; Send data to LCD
BCF LCD_CNTL, RW ; Set LCD to read
BSF LCD_CNTL, RS ; Set LCD to data mode
BSF LCD_CNTL, E ; toggle E for LCD
BCF LCD_CNTL, E
MOVF CHAR, W
ANDLW 0x0F ; Get lower nibble
BCF LCD_CNTL, E
RETURN
;* SendCmd - Sends command to LCD *
;* This routine splits the command into the upper and lower *
SEND_CMD
SWAPF CHAR, W
BCF LCD_CNTL, RS ; Set LCD to command mode
BCF LCD_CNTL, E
MOVF CHAR, W
BCF LCD_CNTL, E
RETURN
page
;* This routine checks the busy flag, returns when not busy *
;* Affects: *
;* TEMP - Returned with busy/address *
BUSY_CHECK
if ( Debug )
BSF PORTD, 3
BCF PORTD, 3
endif
CLRF LCD_DATA ;** Have PORTB<3:0> output low
BSF OPTION_REG, NOT_RBPU ; Turn off PORTB Pull-up
MOVLW 0xFF ; Set PortB for input
MOVWF LCD_DATA_TRIS
BCF LCD_CNTL, RS ; Set LCD for Command mode
BSF LCD_CNTL, RW ; Setup to read busy flag
BSF LCD_CNTL, E ; Set E high
BCF LCD_CNTL, E ; Set E low
SWAPF LCD_DATA, W ; Read upper nibble busy flag, DDRam address
ANDLW 0xF0 ; Mask out lower nibble
MOVWF TEMP ;
BSF LCD_CNTL, E ; Toggle E to get lower nibble
BCF LCD_CNTL, E
MOVF LCD_DATA, W ; Read lower nibble busy flag, DDRam address
ANDLW 0x0F ; Mask out upper nibble
IORWF TEMP, F ; Combine nibbles
BTFSC TEMP, 7 ; Check busy flag, high = busy
GOTO BUSY_CHECK ; If busy, check again
BCF LCD_CNTL, RW
MOVLW 0xF0 ;
MOVWF LCD_DATA_TRIS ; RB7 - 4 = inputs, RB3 - 0 = output
RETURN
page
;***** Start program here, Power-On Reset occurred.
START ; POWER_ON Reset (Beginning of program)
MOVLW 0x0C ; Decimal 12
MOVWF HRS ; HOURS = 12
CLRF MIN ; MIN = 00
MOVLW 0x00 ;
MOVWF FLAG_REG ; PM light is on
MOVLW 0x04 ; Initial value of seconds (64d - 60d)
MOVWF SECS ; This allows a simple bit test to see if 60
; secs has elapsed.
MOVLW 0x80 ; TIM1H:TMR1L = 0x8000 gives 1 second
MOVWF TMR1H ; overflow, at 32 KHz.
CLRF TMR1L ;
MCLR_RESET ; A Master Clear Reset
CLRF STATUS ; Do initialization (Bank 0)
CLRF INTCON
CLRF PIR1
MOVLW 0x00 ; The LCD module does not like to work w/ weak pull-ups
MOVWF OPTION_REG ;
CLRF PIE1 ; Disable all peripheral interrupts
MOVLW 0xFF ;
MOVWF ADCON1 ; Port A is Digital (for 16C7x devices).
CLRF PORTA ; ALL PORT output should output Low.
CLRF PORTB
CLRF PORTC
CLRF PORTD
CLRF PORTE
BCF T1CON, TMR1ON ; Timer 1 is NOT incrementing
BSF STATUS, RP0 ; Select Bank 1
CLRF TRISA ; RA5 - 0 outputs
MOVLW 0xF0 ;
MOVWF TRISB ; RB7 - 4 inputs, RB3 - 0 outputs
CLRF TRISC ; RC Port are outputs
BSF TRISC, T1OSO ; RC0 needs to be input for the oscillator to function
CLRF TRISD ; RD Port are outputs
CLRF TRISE ; RE Port are outputs
BSF PIE1, TMR1IE ; Enable TMR1 Interrupt
BCF OPTION_REG, NOT_RBPU ; Enable PORTB pull-ups
BCF STATUS, RP0 ; Select Bank 0
MOVF PORTB, F ; Need to clear 1st RBIF, due to
BCF INTCON, RBIF ; set up of PORTB
page
; Initilize the LCD Display Module
CLRF LCD_CNTL ; ALL PORT output should output Low.
DISPLAY_INIT
MOVLW 0x02 ; Command for 4-bit interface
MOVWF LCD_DATA ;
BSF LCD_CNTL, E ;
BCF LCD_CNTL, E ;
; This routine takes the calculated times that the delay loop needs to
; be executed, based on the LCD_INIT_DELAY EQUate that includes the
; frequency of operation. These uses registers before they are needed to
; store the time.
LCD_DELAY MOVLW LCD_INIT_DELAY ;
MOVWF MSD ; Use MSD and LSD Registers to Initilize LCD
CLRF LSD ;
LOOP2 DECFSZ LSD, F ; Delay time = MSD * ((3 * 256) + 3) * Tcy
GOTO LOOP2 ;
DECFSZ MSD, F ;
END_LCD_DELAY
GOTO LOOP2 ;
; Command sequence for 2 lines of 5x7 characters
CMD_SEQ MOVLW 0X02
MOVWF LCD_DATA
BSF LCD_CNTL, E ;
BCF LCD_CNTL, E ;
MOVLW 0x08 ;
MOVWF LCD_DATA ;
BSF LCD_CNTL, E ;
BCF LCD_CNTL, E ;
; Busy Flag should be valid after this point
MOVLW DISP_ON ;
CALL SEND_CMD ;
MOVLW CLR_DISP ;
CALL SEND_CMD ;
MOVLW ENTRY_INC ;
CALL SEND_CMD ;
MOVLW DD_RAM_ADDR ;
CALL SEND_CMD ;
page
; Initialize the Special Function Registers (SFR) interrupts
CLRF PIR1 ;
MOVLW 0x0E
MOVWF T1CON ; RC1 is overridden by TCKO
BSF INTCON, PEIE ; Enable Peripheral Interrupts
BSF INTCON, RBIE ; Disable PORTB<7:4> Change Interrupts
BSF INTCON, GIE ; Enable all Interrupts
CALL INIT_DISPLAY ;
CALL DISPLAY ;
MOVLW 0x0E
MOVWF T1CON ; Enable T1 Oscillator, Ext Clock, Async, prescaler = 1
BSF T1CON, TMR1ON ; Turn Timer 1 ON
if ( PICMaster )
lzz goto lzz ; Loop waiting for interrupts (for use with PICMASTER)
else
SLEEP_LP SLEEP ; Wait for Change on PORTB interrupt. or TMR1 timeout
NOP ;
GOTO SLEEP_LP ;
endif
; Here is where you do things depending on the type of RESET (Not a Power-On Reset).
OTHER_RESET BTFSS STATUS,NOT_TO ; WDT Time-out?
WDT_TIMEOUT GOTO ERROR1 ; YES, This is error condition
if ( Debug_PU )
goto START ; MCLR reset, Goto START
else
GOTO MCLR_RESET ; MCLR reset, Goto MCLR_RESET
endif
if (Debug )
END_START NOP ; END lable for debug
endif
page
org TABLE_ADDR
NUM_TABLE MOVWF TEMP ; Store value to TEMP register
MOVLW HIGH (TABLE_ADDR) ; Ensure that the PCLATH high has the
MOVWF PCLATH ; correct value
MOVF TEMP, W ; Value into table
ANDLW 0x0F ; Mask to 4-bits (00 - 0Fh)
NUM_TBL ADDWF PCL, F ; Determine Offset into table
RETLW '0' ; ASCII value of "0" in W register
RETLW '1' ; ASCII value of "1" in W register
RETLW '2' ; ASCII value of "2" in W register
RETLW '3' ; ASCII value of "3" in W register
RETLW '4' ; ASCII value of "4" in W register
RETLW '5' ; ASCII value of "5" in W register
RETLW '6' ; ASCII value of "6" in W register
RETLW '7' ; ASCII value of "7" in W register
RETLW '8' ; ASCII value of "8" in W register
RETLW '9' ; ASCII value of "9" in W register
; Any enter after is in error (Display an E)
RETLW 'E' ; ASCII value of "E" in W register
NUM_TBL_END RETLW 'E' ; ASCII value of "E" in W register
if ( (NUM_TBL & 0xFF00) != (NUM_TBL_END & 0xFF00) )
MESSG "Warning: Table NUM_TBL crosses page boundry in computed jump"
endif
org PMEM_END ; End of Program Memory
GOTO ERROR1 ; If you get here your program was lost
end
