pwm to dc converter
Hi there,
I'm working on a boost DC/DC converter to charge a 12V sealed lead acid battery from a solar panel at the moment. Basically, I've replaced the BJT with MOSFET and the diode with a Schottky Diode. Apart from all this, how do I further increase the efficiency of my DC/DC converter?
I will be feeding the MOSFET with a PWM signal from a PIC Microcontroller. Is there anything that I can do with the PWM signal to obtain a maximum power point at the output of the boost DC/DC converter? Should I control the PWM signal by getting some feedback from the battery to control the step-up voltage level? By doing so, am I improving the efficiency of the boost DC/DC converter? If yes, mind to suggest on how can I get it done? Please?
Any advice? Help really needed...Thanks in advance...
