amrstaha
Full Member level 2
I'm using PIC16F876 in a circuit that turns ON/OFF a solenoid valve. The valve coil works with 220V AC. I use a relay between the microcontroller and the solenoid valve. Eventually, when the valve switches, the microcontrollers resets. Coud you help me solve this problem?
Thank you in advance.
