Dec 25, 2007 #1 S sudhir258 Junior Member level 2 Joined Dec 23, 2006 Messages 22 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,431 mirocontroler I WANTED TO KNOW THAT CAN WE USE "PIC16F628" INSTEAD OF "PIC16F84A"
Dec 25, 2007 #2 T tyildizak Newbie level 6 Joined Dec 19, 2006 Messages 12 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,327 Yes , you can use , but there ara some differencies: 1. You can use internal osc. with 16f628. If you use int. osc then you'll have 2 more pins (porta.6, porta.7) 2. If you want to use porta as digital inputs , you have to set: CMCON = 7 ;disable comparator inputs VRCON = 0 ;disable a/d voltage reference
Dec 25, 2007 #3 S sudhir258 Junior Member level 2 Joined Dec 23, 2006 Messages 22 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,431 basically i am using the following pins :- RA2, RB1, RB2, RB3, RB4, RB5, RB6, RB7, MCLR , CLK IN/OUT. SO WHAT ARE THE CHANGES TO BE MADE. ALSO LET ME KHOW IF THERE IS ANY SOFTWARE CHANGE to be made for pic16f628
Dec 26, 2007 #4 ravimarcus Full Member level 4 Joined May 9, 2005 Messages 218 Helped 31 Reputation 62 Reaction score 12 Trophy points 1,298 Location Bangalore, INDIA Activity points 2,797 sudhir258 said: I WANTED TO KNOW THAT CAN WE USE "PIC16F628" INSTEAD OF "PIC16F84A" Click to expand... Check this out ... **broken link removed** Cheers Ravi
Dec 26, 2007 #5 S Split841 Junior Member level 2 Joined Apr 14, 2007 Messages 22 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location Slovakia Activity points 1,401 and you can program it through jdm programator so as 16f84
Dec 26, 2007 #6 F faraz101 Full Member level 1 Joined Mar 7, 2007 Messages 96 Helped 7 Reputation 14 Reaction score 5 Trophy points 1,288 Activity points 1,872 but remember that u have to gnd pin no 10(PGM/RB4) via 1k resistor.other wise jdm will not progrmme that.i have faced that problem
