maark6000
Member level 5
- Joined
- Jan 15, 2013
- Messages
- 92
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 2,270
So, I thought I understood this downloading of one's program onto a chip. You plug your programmer (ICD3 in my case) into your USB port on your computer, you connect your target board via the mildly trustworthy RJ-11 cable, insert your chip into the board, and download your program. Since two of the connections from the programmer are Vdd and Vss, the PROGRAMMER will power your chip while downloading / debugging.
But then, that didn't work. MPLAB X kept giving me a "target not found" error, and a little clue was dropped with a dialogue window that opens up and begs "are you sure you're not using a 3.5V chip in there?"
Doing some searching of the internet for the "target not found" error, I found someone respond "the programmer doesn't think the chip has power." Wait a minute. If it's in the programmer... it has power... why else would there be Vdd and Vss pins? But then I thought well, what could it hurt if I try to jam 5 volts into the chip WHILE it's in the programmer... I mean these things are made to work in situ, right? So I did and voila... the program downloaded.
So, my question is... a: did I do that right? and b: am I completely crazy to mistakenly think that the programmer would power the chip while it was in there? and c: I have been reading a book and plenty of microchip documents on programming PIC microcontrollers... why have I never once read "Oh by the way, the chip must be independently powered from some other source than your programmer when you are trying to program it."?
Frustrating.
Frustrating.
