pic low voltage programming with pickit2
devil6600
Full Member level 5
Full Member level 5
i have built a circuit with pic16f877a, how can i program it using low voltage programming? can it be done using pickit2. i don't have pickit2, but if it can be done i'll buy one.
low voltage because i don't want to damage the other components on board
thanks
High voltage programming doesn't damage other components because the high voltage only goes on the PIC MCLR pin. You can program it with a low voltage though provided your Vcc is 5V. https://ww1.microchip.com/downloads/en/DeviceDoc/39589C.pdf You need some sort of programmer though.
Keith.
As Keith mentioned, if your PIC circuit is wired correctly, the PICkit 2 will not damage any component during programming. The PICkit 2 is actually a nice programmer/debugger, a good choice for an entry level unit and has several nice features.
Here's the PICkit 2 product page:
Contains all the documentation concerning the PICkit 2 as well as its device support list, which includes the PIC 16F877A.
PICkit 2 User's Manual:
PICkit™ 2 Programmer/Debugger User's Guide
PIC 16F877A Product Page, always obtain the latest datasheet for your MCU:
PIC16F87XA Data Sheet
The datasheet usually has example circuits for clock, programming pins, etc.
The ICSP Guide:
In-Circuit Serial Programming™ (ICSP™) Guide
PROGRAMMING THE PIC16F87XA
The info above should answer any questions you have concerning your PIC 16F877A, the PICkit 2 would be a good choice.
Ciao
