shanix
Newbie level 3
- Joined
- Oct 28, 2014
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 21
Im just learning pi16 programing using mikroc pro for pic and im having trouble displaying my variable which is X1 in lcd. This is my code
The lcd displays correctly if only i changed the if else condition with something like this
if(1 < 2){//perform calulation}
else if(1 > 2){//perform calulation}
Im just learning pic hope someone could help me out with this..thank you.
int main2 (unsigned int a[]); //function to get array largest element position
sbit LCD_RS at RD4_bit;
sbit LCD_EN at RD5_bit;
sbit LCD_D4 at RD0_bit;
sbit LCD_D5 at RD1_bit;
sbit LCD_D6 at RD2_bit;
sbit LCD_D7 at RD3_bit;
sbit LCD_RS_Direction at TRISD4_bit;
sbit LCD_EN_Direction at TRISD5_bit;
sbit LCD_D4_Direction at TRISD0_bit;
sbit LCD_D5_Direction at TRISD1_bit;
sbit LCD_D6_Direction at TRISD2_bit;
sbit LCD_D7_Direction at TRISD3_bit;
unsigned int DataA[3] = {9,2,3};
unsigned int DataB[3]= {1,9,3};
unsigned int DataC[3]= {1,2,9};
float Time[3]= {0.2,0.4,0.8};
float ta,tb,tc;
int index;
float V1,tab1,tcb1,L1=1.00,X1;
char txt[15];
void main() {
PORTA = 0;
TRISA = 0X01;
TRISB =0 ;
PORTB = 0;
TRISD =0 ;
PORTD = 0;
LCD_Init();
LCD_Cmd(_LCD_CURSOR_OFF);
LCD_Cmd(_LCD_CLEAR);
LCD_Out(1, 1, "ANSWER:");
index = main2(DataA); //get DataA max element position
ta = Time[index]; // use the position to get data from Time
index = main2(DataB);
tb = Time[index];
index = main2(DataC);
tc = Time[index];
tab1 = ta-tb;
tcb1 = tc-tb;
delay_ms(200);
///for calculation
if(tab1 < tcb1){
V1 = (float)1/(2*tcb1);
X1 = 0.5*( (V1*tab1)+ (0.5*1) );
else if(tab1 > tcb1){
V1 = (float)1/(2*tab1);
X1 = (1-0.5)*( (V1*tab1)+ (0.5*1) );
FloatToStr(X1, txt);
delay_ms(500);
LCD_Out(2,1,txt);
while (1){}
int main2 (unsigned int a[]){
int pos;
unsigned int c;
unsigned int maximum = a[0];
unsigned int x;
for (c = 1; c < 3; c++)
x = a[c];
if ( x > maximum)
maximum = a[c];
pos = c;
return pos;
