Pic !8f4550 I want to blink some led
jsureshp
Junior Member level 3
Chennai
please anybody help me please
I'm using the Mplab ide and hitech c compiler
Pic 18f4550
is there any alternative software for Mplab Ide?
Added after 3 minutes:
The source file i added
and how can i add the header file?
where it will be available
MPLAB IDE is good enough for PIC.
you can install the upgraded version of c compiler.
I use CCS C compiler and there is full support for 18f series.
or as millwood says try to use address instead of names e.g address of Porta .
As Error Message says: unable to locate htc.h & delay.h
find these files are supported by your compiler or not?
Regards.
Actually
My compiler not show the header file.
It shows from pic 12series to pic 16series only can you tel the upgrade version for the c compiler
or give the link for the version for the pic
I recommend mikroElectronika
Free to use (up to 2K) compilers and very nice IDE
Excelent support.
Give it a go
jack
the header file for pic 18series are not availlble in my system
Added after 1 minutes:
That means Mikro c software
correct?
you can visit the site of Microchip.
www.microchip.com
www.ccsinfo.com
you will find there latest version of ccs c compiler but you have to get license from ccs.
if your application is small enough you can go for the free version of mikroElectronika as 123jack suggests.
regards.
ok
shall you give the hex file for blinking led
Added after 11 minutes:
and i also installed the ccs compiler for pic
this also showing the header file from pic 12series to pic 16series only
Added after 35 seconds:
now what i do?
Added after 18 minutes:
now what i do?
Added after 38 minutes:
now what i do?
From your picture, the code is written for Hi-Tech PICC18 compiler but the compiler used is Mplab C18. You use wrong language toolsuit.
-ichan
Go to the mikroElekronika web site and download (yes) MikroC
Open up the example files and compile one of the two LED blinking
examples given.
jack
jsureshp said:
ok
now what i do?
now what i do?
now what i do?
if you have installed a latest version of CCS C Compiler then there is no point why you don't have 18 series header file?
in your project wizard choose proper language toolsuite.
Recheck your project settings ( proper compiler ,device ,language toolsuite) .
Hope this will help you.
Regards.
