PIC 24f series and lcd
lats
Full Member level 4
Dear frnz
I want to design a project using pic24f series and 16 x 2 LCD. My problem is that pic 24f series work on 3.3 v operating voltage while lcd needs 5 v to operate .i want to connect many periperals like pendrive etc. which also operate on 5 v. how to solve this problem? please help.
thanku
lats
Industry standard HD44780 compatible LCD controllers have a TTL level specification. They can work 3.3V with CMOS output signals. On the other hand, PIC24F I/Os are 5V tolerant (except for some analog pins), so it has no problem to read e.g. the busy bit from LCD controller. In other words, just connecting the LCD and PIC24F should be fine.
As the second option, most LCD controllers also work with 3.3V supply, check your datasheet. But you usually need a negative voltage at the contrast pin.
Also worth mentioning most LCDs with HD44780 compatible LCD controllers are available in a 3.3v version:
Sparkfun LCDs
Many other peripherals are available in a 3.3v version as well.
BigDog
Reactions: FvM
    FvM
