You would need to enable Global Interrupt by setting GIE=1. You then need to set the required INT module interrupt by setting, eg, INT0IE=1. Configure which edge to "use" for generating the interrupt by selecting the correct value for the required INTEDG bit. Go to section 9.0 - Interrupts in the datasheet for the registers.
