PIC 18F452, mmc, FAT system, mikroC
davenjose
pic mmc fat
hi there,i am currently on a project entitled Digital Altimeter using SD Card as storage.
i am writing a file (data) to mmc with PIC 18F452 using FAT system and mikroC as compiler.
the data that i am going to write on a mmc is from the reading of our pressure sensor that would be converted to an altitude by the PIC.
i would like to ask some advice on the code for this process (or the code).
i am using mikroC that provides library on mmc, but i am still a beginner and not very confident on my code.
is it possible that i could read or open the file on my mmc with a card reader to a PC after writing data to it?
please help, i really need to finish this project a short time from now.
thank you.
Did you succeed in your operation ? Because I want to do the same thing...
Reactions: dtr
    dtr
The subject is a little old, sorry.
Yes of course you can read the SD card on your PC, that's the purpose of the
file system.
I did this implementation today, and I reach an accuracy of 25 cm in altitude.
But I am improving the whole system with a new averaging method, which
might increase the accuracy while being more responsive.
Storing in SD card is not a problem. I store directly in text format so that
the file can be opened with excel or compatible software. The consequence
is that the graphic can be done with Excel's utilities. Well, to be honnest, I don't
use Excel, but "Numbers" on a Mac.
Dora.
hi all, can u pls tell abt the procedure you used to store data from the pic microcontroller into the memory card using mikroc... i am a beginner and i dont knw anything about mmc..!!.. help will be greatly appreciated
hey, doraemon, cud u pls tell how u wrote data into card...and give a sample program if possible... thank you
Hi all,
I am currently working on part of fyp that I have to use PIC to read file (txt file) which is stored in a SD Card. I use CCS compiler and PIC18f4620. I fail even in trying to open the file :cry:. Anyone can help me in coding?...i would greatly appreciate if you have a complete code in accessing the file stored in SD and read the data from the txt file.
The CCS driver files that i use for MMC are fat.c and mmcsd.c.
Thanks. Hope to get helps from you all. And hope to get replies as soon as possible.As it is urgent. Thanks much.
regards,
sandy
Hi Davenjose,
I am trying to implement a FAT filesystem on PIC18 as well, but I´m struggling with it.
Do you have code examples for PIC18 and FAT? How do you compile everything together? What library are u using?
Thanks and best regards
The Microchip library looks good, is it for free?
What compiler is it for? Have you worked with it before?
Added after 1 hours 16 minutes:
I have downloaded the files and it looks quite interesting, however I don´t know where to start, how to integrate it with my application and my low level routines, make it work on my board, etc.
Has anybody worked with this library before and integrated it into a target application on PIC18?
hello
It is very simple one.
I put the code here, the code is working one it create a text file name mikroc.txt
char
 faterror[20] = "FAT16 not found",
 filecontents[50] = "XX MMC/SD FAT16 library by Anton Rieckert\n";
//char filename[14] = "MIKRO00.TXT";          // File names
unsigned short tmp, charecter, loop;
unsigned long i, size;
void main()
     PORTB = 0;
     TRISB = 0;
      trisd=0x00; ;
      portd=0x00;
     Usart_Init(9600);
     Delay_100ms();
   //   portd=0xff;
      Delay_ms(3000);
     Spi_Init_Advanced(MASTER_OSC_DIV64, DATA_SAMPLE_MIDDLE, CLK_IDLE_LOW, LOW_2_HIGH);
  //  Spi_Init();
   Mmc_Init(&portC,2);
     // use fat16 quick format instead of init routine if a formatting is needed
     while ((Mmc_Fat_Init(&PORTC, 2)!=0))
         tmp=0;
         while(faterror[tmp])
         Usart_Write(faterror[tmp++]);
         portd=0x0f;
        // Mmc_Fat_Assign("mikroc.txt",0x80);
         Delay_ms(1000);
         portd=0x00;
      for(loop=1;loop<=5;loop++)
           Spi_Init_Advanced(MASTER_OSC_DIV4, DATA_SAMPLE_MIDDLE, CLK_IDLE_LOW, LOW_2_HIGH);
          filename[7]=loop+64;
           portd=0xff;
           Delay_ms(1000);
      //    Mmc_Fat_QuickFormat(&portc,2,"MIKRO00.TXT");
          Mmc_Fat_Rewrite();
          filecontents[0]=loop/10 +48;
          filecontents[1]=loop%10 +48;
          Mmc_Fat_Write(filecontents,41);
          Mmc_Fat_Append();
           portd=0x00;
          Delay_ms(200);
          portd=0xff;
          Delay_ms(1000);
          Mmc_Fat_Assign("mikroc.txt",0xA0);
          portd=0x00;
          Mmc_Fat_Append();
          Mmc_Fat_Set_File_Date(2010,5,8,10,loop,0);
          Mmc_Fat_Write("mikroc electronica 2010\r\n",30);
          Mmc_Fat_Append();
          Mmc_Fat_Reset(&size);
          for(i=0;i<=size;i++)
            Mmc_Fat_Read(&charecter);
            Usart_Write(charecter);
          Delay_ms(200);
If you have any doubt you can ask me.
Thanks ansarmytheen.
But will this code works for FAT16 only rite! what are the modifications needed if i need to run on a FAT32 MMC caed?
Dear ansarmytheen
can u send me schematic diagram and complete code with included file.
I used this code ,It does not successful in the following line
Mmc_Init(&portC,2);
here what is the usege of USART protocol ? can I use this code without using USART or UART ?
Pleas check MIkroC help ,It contains a circuit diagram which is easy one.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
char
void main()
     PORTB = 0;
     TRISB = 0;
      trisd=0x00; ;
      portd=0x00;
     Usart_Init(9600);
     Delay_100ms();
   //   portd=0xff;
      Delay_ms(3000);
  //  Spi_Init();
   Mmc_Init(&portC,2);
         tmp=0;
         portd=0x0f;
         Delay_ms(1000);
         portd=0x00;
           portd=0xff;
           Delay_ms(1000);
          Mmc_Fat_Rewrite();
          Mmc_Fat_Append();
           portd=0x00;
          Delay_ms(200);
          portd=0xff;
          Delay_ms(1000);
          portd=0x00;
          Mmc_Fat_Append();
          Mmc_Fat_Append();
          Delay_ms(200);
Code C - [expand]
unsigned char Mmc_Init(unsigned short *port, unsigned short pin);
hello,
I tried successfully "petite FAT 32 " on a SDcard 2Go
preformatted in FAT 32 with a PC computer...
my main problem was no card detection on my SDcard Breadboard ,
so i goes over this test (no Card presence test possible..because no hardware for that)
and i can write or read file on SDcard.
Written in C18 MPLAB.. for Pic18F46K22
all details HERE
i will try soon to translate in MikroC.. because now i have a licence and can go over the 2K MikroC limit..
This is the basic code to save the temperature on SD card. Written in MikroC. And simulated in Proteus.
HTML:
#define BUFFER_SIZE 15
//Memory Card Chip Select Connection
sfr sbit Mmc_Chip_Select at RB2_bit;
sfr sbit Mmc_Chip_Select_Direction at TRISB2_bit;
// LCD module connections
sbit LCD_RS at RD0_bit;
sbit LCD_RW at RD1_bit;
sbit LCD_EN at RD2_bit;
sbit LCD_D4 at RD4_bit;
sbit LCD_D5 at RD5_bit;
sbit LCD_D6 at RD6_bit;
sbit LCD_D7 at RD7_bit;
sbit LCD_RS_Direction at TRISD0_bit;
sbit LCD_EN_Direction at TRISD2_bit;
sbit LCD_D4_Direction at TRISD4_bit;
sbit LCD_D5_Direction at TRISD5_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D7_Direction at TRISD7_bit;
// End LCD module connections
unsigned char filename[] = "Temp.TXT";
unsigned char error;
unsigned char i;
unsigned int adc_value;
unsigned char Temperature_Log[BUFFER_SIZE];
void main()
 unsigned char ones,tens,hundreds;
 unsigned int temp;
 TRISD = 0x00;
 Lcd_Init();
 Lcd_Cmd(_LCD_CURSOR_OFF);
 Lcd_Cmd(_LCD_CLEAR);
 Delay_ms(100);
 Lcd_Out(1,1," TEMP. RECORDER");
 Lcd_Out(2,1,"  BY HEMNATH  ");
 Delay_ms(1000);
 ADCON0 = 0b00000001;    //A/D Converter Power Up
 ADCON1 = 0x00;          //All Analog Channels
 ADCON2 = 0b10111110;    //Right Justfied and Slowest Clock for better accuracy
 ADC_Init();
 SPI1_Init();
 SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV64, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
 Delay_us(10);
 error = MMC_Init();
 while(error == 1)
  Lcd_Out(1,1," CARD NOT FOUND");
  error = MMC_Init();
 Lcd_Out(1,1," CARD DETECTED!");
 Lcd_Out(2,1,"CARD INITIALIZED");
 Delay_ms(1000);
 MMC_Fat_Init();
 SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV4, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
 Mmc_Fat_Delete();
 Mmc_Fat_Assign(&filename,0xA0);
 Lcd_Out(1,1,"TEMPERATURE:");
 while(1)
  adc_value = ADC_Read(0);      //Read Temperature from ADC
  adc_value = adc_value*488;
  adc_value = adc_value/10;
  temp = adc_value/100;
  Temperature_Log[0] = 'T';
  Temperature_Log[1] = 'E';
  Temperature_Log[2] = 'M';
  Temperature_Log[3] = 'P';
  Temperature_Log[4] = '=';
  ones = temp%10;
  temp = temp/10;
  tens = temp%10;
  temp = temp/10;
  hundreds = temp%10;
  ones = ones|0x30;
  tens = tens|0x30;
  hundreds = hundreds|0x30;
  Temperature_Log[5] = hundreds;
  Temperature_Log[6] = tens;
  Temperature_Log[7] = ones;
  Temperature_Log[8] = '.';
  Lcd_Chr(2,1,hundreds);
  Lcd_Chr(2,2,tens);
  Lcd_Chr(2,3,ones);
  ones = adc_value%10;
  tens = adc_value%10;
  ones = ones|0x30;
  tens = tens|0x30;
  Temperature_Log[9] = tens;
  Temperature_Log[10] = ones;
  Temperature_Log[11] = ' ';
  Temperature_Log[12] = 'C';
  Temperature_Log[13] = '\r';
  Temperature_Log[14] = '\n';
  Lcd_Chr(2,4,'.');
  Lcd_Chr(2,5,tens);
  Lcd_Chr(2,6,ones);
  Lcd_Chr(2,7,223);
  Lcd_Chr(2,8,'C');
  Mmc_Fat_Append();
  Mmc_Fat_Write(Temperature_Log,15);
  Delay_ms(300);
  • TEMP.TXT
hello,
Thank's for sharing your solution ..but
you wrote ,in another post
It works good. and I have tested in proteus. Not in hardware.
is it always true ?
Plenty of hobyst do not use Proteus ..because of his high cost..
so only work in real world..
The advantage is .. we can be confident if it's work , and get a result.
not the same in simulation.
With MikroC ,we must trust with a complete library without to know details
and if it doesn't work .. we are "Chocolat " ( What about to do ?)
Even this, i will try also by myself your solution, in real world , and give here a feedback
within any days..
I believe that most people using mikroC do it for the comfort of the built-in libraries. On the other hand, it's a full featured C compiler, you are free to use other libraries, e.g. popular FATFS.
I agree with you, it's the main raison i payed for, to get a MikroC Licence (without 2K limit)..
But Comfort means also less basis knowledge for the user..
Fortunatly i started with ASM compiler , then C18 MPLAB ..
and wanted only one compiler for all range of 8bits PIC family. MikroC is one solution of many others.
and because i fund MPLABX too heavy to handle..too many directorie and files ..
even it could be very performant for big project..
(it is my own opinion..not shared by all , of course ! )
i don't forget also, that a compiler is never 100% free of bug, with a so large panel of PIC12..16..18.
