pic 16f877A data transfer with ADC converter and LCD display
demetal
Full Member level 5
Full Member level 5
Kingdom Of Kochi
hi,
i have to transmit a digital data after ADC conversion (from a sensor) and send it another PIC16f877A where i need to display the result in an lcd...
I am using mikroC compiler... i dont know how to write the code for the operation...if any one know the codes please help.....:grin:
You can use SPI or I2C protocol to setup communication between two 16F877As The following example uses an I2C protocol:
First of all you should pay attention during the classes that you took, second, try to read the examples that came with the compiler, third, try to write some code and then ask for help.
No one is going to do your homework.
hi,
Thanks for your kind advice.... i am new to this field.... i dont know very much about PIC microcontrollers as i studied only about few features 8051 in classes....
---------- Post added at 19:17 ---------- Previous post was at 19:13 ----------
[/COLOR]hi,
Thanks for the in formation ...but i am interested in UART one way communication i.e; from tx of one pic to rx of another pic.
LaTeX Commands Quick-Menu:
