[PIC] PIC 16f877a coding..
ahmadfaizzakian
Newbie level 2
Newbie level 2
hello,im new around here and im not limited internet connection. im doing a project named automatic handwash with auto refill. well here is my coding. im using mikroC for the coding.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
void portb0() ;
void main() {
  int mot0 = 0;
  int mot1 = 0;
  TRISA = 0b00000000;
  PORTA = 0x00;
  TRISB = 0b00000000;
  PORTB = 0x00;
  TRISC = 0b11111111;
  PORTC = 0x00;
  TRISD = 0b11111111;
  PORTD = 0x00;
while (1)
if (PORTC.f0 == 1)
while(1)
portb0() ;
if (porta.f1 = 0)
   portd.f2 = 1 ;
   delay_ms(5000) ;
if (porta.f2 = 0)
   portd.f3 = 1;
   delay_ms(5000) ;
break ;
else
PORTB == 0 ;
void portb0 (void) {
     portb.f0 = 0x00000001 ;  //air
     delay_ms(600) ;
     portb.f0 = 0x00000000 ;
     portb.f1 = 0x00000001 ;  //sabun
     delay_ms(150) ;
     portb.f1 = 0x00000000 ;
     delay_ms(600) ;
     portb.f2 = 0x00000001 ;  //blower
     delay_ms(600) ;
     portb.f2 = 0x00000000 ;
     portb.f3 = 0x00000001 ;  //sanitizer
     delay_ms(150) ;
     portb.f3 = 0x00000000 ;
based on the coding, i manage to get all the washing circuit to work, but my problem is on the refill circuit as i dont know the coding. i know that port A can be used as ADC but i dont know how to use it. my liquid level sensor circuit work properly but i need the coding on PIC. i want to make when port A2 and A3 read 0V,it will turn on port D2 and D3.. can anyone help me?? im really noob in this:-(
please and thank you
hello,
so,is it an analog level sensor.?
if yes, what kind of signal is delivered by this ?
it must be in the range 0 to 5 V for all of the measuring range..
do you have 2 analog sensors ?
or 2 dry contact ?
Explain clearly to get support...
Maybe with a drawing with sensor location ..water circulation..
hello,
or 2 dry contact ?
yes the output is 5V..but i need it to be 0V which means the PIC read it as logic 0. it is the same circuit actually. but i make it 2. i will attach my circuit. im sorry mate.
