PIC 16f877 DC motor control
omsi
Member level 5
Member level 5
London
pic16f877 dc motor
hi,
if u search for program for dc motor controller using pic16f877 u get the sample program for that using pwm.try out.
using encoder to pic16f877a
Hi guys...i'm also having a same job with u. I got to use PIC16F876 to generate PWM to control the motor bridge with feedback system and to change the direction at the same time.
Is there any way to obtain the sample program regarding to this case?
pic16f877a and dc motor
I've tried to simulate pwm with isis.I can see the pwm waveform on the scope but i can't see any voltage when i measure with a dc voltmeter.What's the problem?
pwm using pic16f877a
hi guys,
i am working on the same project too... mind to share your schematic circuit?
pic16f877 motor control
Here's a ISIS model on controlling DC motor with PWM.It's in PIC BASIC.
Reactions: baristura
    V
    baristura
dc motor control with pic16f877
tipically, that's what u need!
Reactions: xiexin
    coshkun
    xiexin
pwm using pic16f877
thank you very much! Does opto-encoder a typical way for speed sensing? Is there any alternative to sense the speed?
how cuntrol pwm inpic16f877
Also you can you use a tacometer to sense the speed but that's the older way of doing this.
    V
control motor pic16f877
What do you use in your dc contrller to drive the motor? H-bridge,MOSFETs ... etc?
16f877 dc motor
Yes. Full bridge with mosfets. Controlled by PIC16F877A.
picc pwm
how about hall effect sensor....try this... sense the magnitude field of the DC motor and output digtial signal back to PIC...
pic16f877 pwm controller
Can any body tell are there any predefined PWM, ADC, UART function in HItech C Compiler i m using PICC Version 8.03PL1
PLease help
Reactions: aqua60
    aqua60
pic 16f hall
any sample of using PIC 16f877 with the hall effect speed sensor? thanx
dc motor to pic16f877a
This code written in Proton Plus Compiler to control the illumination of the LED
device 16f630
xtal = 10
all_digital = 1
dim VALUE as byte
symbol SW1 = portc.0
SYMBOL SW2 = PORTc.1
value = 0
CHK1:
if value < 255 then
IF SW1 = 0 THEN
VALUE = VALUE + 1
ENDIF
endif
if value > 0 then
IF SW2 = 0 THEN
VALUE = VALUE - 1
endif
ENDIF
pwm porta.0, value, 100
goto CHK1
END
16f877a control motor
hi
whats the best compiler for pic16f877a??
pwm ccs 16f877
syahrul.s said:
hi
Search the board, you will get your answer. But I think any compiler is good depending on the kind of application.
You can use CCS C, it is user friendly, but don't expect that it is the best.
dcmotor+pic16f877a
glenjoy said:
syahrul.s said:
hi
Dearfriend, glenjoy
I prefer to use Proton Plus Compiler it is powerfull compiler
Re: dc motor to pic16f877a
device 16f630
xtal = 10
all_digital = 1
dim VALUE as byte
value = 0
CHK1:
if value < 255 then
IF SW1 = 0 THEN
VALUE = VALUE + 1
ENDIF
endif
if value > 0 then
IF SW2 = 0 THEN
VALUE = VALUE - 1
endif
ENDIF
goto CHK1
END
Reactions: xiexin
    xiexin
