raghavathej
Junior Member level 3
How do we do Physical Synthesis using Cadence RTL Compiler?:?:
For once i tried it with Physical synthesis command reference, it successfully completed with necessary flow.:|
But i have not given any floorplan file for it.:-x How do i write a floorplan file specific to Physical synthesis.:?:
Is there any good PDF available to write a floorplan file? Please mention syntax to write floorplan file or can we generate such .fp file automatically?
Also, what type of output/netlist is generated after Physical Synthesis.
Thank You.
Thank You.
