santais
Junior Member level 1
Hi all.
I've been struggling with my Photodiode Transimpedance Amplifier for some time now and was hoping some of you could help me make this a bit more clear.
So far I've tried to measure the output voltage in different light conditions, which gives a reasonable output. Using the -Id * Rf = Vout and calculating a output of 5V (Vmin = GND Vdd = 5V), got me to a resistor of approximately 400 KΩ. When i measure the Vout of my operational amplifier relative to ground, there's basically no output signal. If I measure the voltage across the resistor, I can measure the desired output, which also makes sense.
My question is: When I measure the Vout of the amplifier relative to ground, isn't that my actual amplfication, which is lead further on into the circuit. This output is supposed to be fed into an ADC converter.
OP Amp: LM358N
Rf = 400KΩ
Cf = 5.7p pF
OP Amp: LM358N
Rf = 400KΩ
Cf = 5.7p pF
