Tunelabguy
Full Member level 5
- Joined
- Jan 3, 2011
- Messages
- 319
- Helped
- 92
- Reputation
- 184
- Reaction score
- 89
- Trophy points
- 1,308
- Activity points
- 4,228
I would like some comments on a photodiode amp I am designing. I would like to make it with several different switchable sensitivities. The basic design is a LTC6241 op amp with the PIN photodiode connected in photovoltaic mode (transimpedance amplifier configuration). The photodiode goes to a virtual ground at the (-) input of the amp along with a feedback resistor. The size of this feedback resistor determines the sensitivity. What I would like to do is switch in several different feedback resistors using a JFET switch. As some of these resistors might be in the multi-megohms, I want to be very careful about leakage current. The BFT46 is a very small JFET with a cut-off drain current of less than 0.5nA and a gate leakage of less than 0.2nA. Since the Source of the FET goes to the (-) input of the op amp, which is held at virtual ground, the gate only needs to be driven to either 0v or -5v to switch on or off the feedback resistor connected to its drain.
I have never seen a photodiode transimpedance amp configured this way, so I suspect that something is wrong with the approach. Can anyone comment on the approach or tell me what is likely to cause me trouble if I do things this way? For example, should I take great pains to LP filter the gate drive to these FETs? I am not concerned about behavior during the transition between different gains. It is OK if switching gains causes a temporary spike due to capacitively coupled gate drive getting to the summing junction. But after a few msec I need things to operate as if only a single feedback resistor was connected.
The application is for timing reference for a prop balancer for small planes. I plan to shine an artificial light source on the front of the prop and pick up the shadow of the prop from behind the prop with this photodiode.
