Debdut
Full Member level 3
I have some difficulty is clearing some concepts.
Suppose there is a forward transfer function G(s) and feedback transfer function H(s). Is PM and GM calculated for G(s)H(s) or simply G(s) in order to determine the stability of the system?
For example in two-stage OpAmp we only calculate the PM for the open loop two-stage amplifier i.e. only G(s) to see whether it is having at least 60 degrees PM irrespective of any feedback path.
However in PLLs or Integer-N Synthesizers we calculate the PM of G(s)H(s), G(s) being the Phase-Frequency Detector, the Loop Filter and the Voltage Controlled Oscillator, H(s) being the Frequency Divider.
Reference to PM calculation of PLL I found in "Fourth-order PLL loop filter design technique with invariant natural frequency and phase margin" by I.V. Thompson and P.V. Brennan.
Are the above statements I made correct? Please help me out! :???:
