biolycans
Member level 2
- Joined
- Aug 24, 2013
- Messages
- 50
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 478
Hi all !!
I have the transfer function a(s)= 5 / (0.00833333 *s^3 + 0.1333333 * s^2 + 0.65833333 * s + 1), and the feedback is f=1
I simulated in Matlab the open loop system (a(s) *f) and the phase margin and gain margin I obtained are: MF= 23.6 degrees and a GM=5.61 dB so the close loop system is stable.
Then if I increase the gain in the close loop system with a value of 5.61 dB, then the Phase margin and gain margin of this open loop system are PM=0 and GM=0 approximately. In the limit of instability.
I understand the concepts of the PM and GM but I still have a question. For the MG, is the amount of gain I can increase to put the close loop system in the limit of instability. and the same with the PM.
In the simulations I can see a relation between PM and GM. Am I correct ? What make me confuse is that for a change in GAIN (constant), it produced changes in gain (GM) and phase (PM) too. so for a gain of 5.61 dB it correspond a change in phase to 23.6. Am I correct ? Because in many books, the phase margin and gain margin are explained like different item but for me the are really related.
Another thing is how can I produce only a change in phase in the system keeping the gain margin ? and the same for the PM keeping the GM ? is this possible ?
Can you help me, please ?
Regards,
Joaquin
Regards,
Joaquin
