phase margin and gain margin op amp
biolycans
Member level 2
Member level 2
I designed an operational amplifier two stages cmos and what I want to do is to verify the phase margin and gain margin of this circuit. What configurations should I use for this circuit ?
Regards
Joaquin
PM and GM are important in a closed loop ckt like a buffer. In open loop configuration the 2stage op-amp is more like a comparator.
So you can use any closed loop configuration, simplest being an unity gain buffer. Then just do a stability analysis and find the PM & GM and compensate accordingly.
Just to avoid misunderstandings:
Unty gain applications with 100% feedback are the most critical configuration as far as the stabilty is concerned.
However, determination of stability margins is done using open-loop configuration (loop gain).
For unity-gain feedback this is identical to measure/simulate the opamps open-loop gain (magnitude and phase).
