Apr 8, 2011 #1 C clarkkent Junior Member level 1 Joined Oct 31, 2010 Messages 18 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location m'sia Activity points 1,378 I am currently designing a single ended to differential converter. How can I performance the analysis for phase error and amplitude error? Thank you.
Apr 12, 2011 #2 C clarkkent Junior Member level 1 Joined Oct 31, 2010 Messages 18 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location m'sia Activity points 1,378 hello, anyone can help to solve this problem? I need to see the phase error and the amplitude error of the output differential signal. Using cadence.
Apr 13, 2011 #3 kspalla Advanced Member level 4 Joined Aug 19, 2008 Messages 1,253 Helped 258 Reputation 516 Reaction score 94 Trophy points 1,328 Location Hyderabad, Andhra Pradesh, India Activity points 6,813 BASICALLY YOU NEED TO WRITE MEASUREMENT EQIATIONS TO FIND THE DIFFERNCE IN PHASE AND AMPLITUTE. Phase diffence should be 180deg, so subtracting 180 deg and presenting the absolute value will give teh phase error. absolute value of Amplitude difference is the amplitude error.
