I want to use the MAX1415 for a new design. Table 2 in the datasheet (https://datasheets.maximintegrated.com/en/ds/MAX1415-MAX1416.pdf) shows the peak-to-peak resolution vs gain and output data rate.
If I look for instance at datarate 20Hz in buffered mode, I calculated the accuracy in uV for any given gain and resolution for a 1.25V reference.
You can see that after a gain of 8, the accuracy in uV is the same. That happens ofcourse because the resolution decreased, but then why should one need a higher gain(PGA), if the absolute accuracy stays the same?
