ljy4468
Full Member level 4
- Joined
- Jul 20, 2005
- Messages
- 232
- Helped
- 13
- Reputation
- 26
- Reaction score
- 1
- Trophy points
- 1,298
- Location
- South Korea
- Activity points
- 3,023
Hi all
I have a question about error amplifier.
There are two way of implement error amp.
Transconductance amp. and convertional voltage-type amp.
Below is TI's datasheet
http://www.abacus.co.uk/jkcm/cache/fl0016340.pdf
'The advantage in using a transconductance amplifier is that the inverting input of the amplifier is solely determined by the external resistive-divider from the output voltage and not the transient behavior of the amplifier itself. This allows the VO_SNS pin to be used for sensing over voltage conditions.'
VO_SNS pin is inverting input of EA.
Now , I wonder why the inverting input of the amplifier is solely determined by the external resistive-divider & why inverting input pin is used for sensing OVP
ONLY possible in transconductance amplifier.
Someone give me an advise.
Regards.
Regards.
