Dear all,
I have designed a chip containing different blocks. Each block is DRC, LVS clean and parasitics have been extracted. At top level when I connect every blocks to each other, Calibre DRC and LVS is clean. The LVS shows exact match between schematic and layout. But When I do PEX to extract the parasitics, the LVS (inside PEX) is incorrect and it is referring to one of the blocks (which is a T-Gate) and 6 of this block have been used. It is indicating that TGATE block is not compared. Error: Ground net is missing in the layout.
However, all the ground of analog blocks have been connected to AGND! . And also in LVS options I have defined the name of the ground nets (AGND and VSS! for digital circuitry). Can any of you help me with this? I do thank you.
Regards,
