Peak detector and charge pump
kowshikd7
Hi
Is there any difference between the charge pump and Dickson charge pump circuit?
Thanks
Kowshik
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
Most voltage multipliers have a final output stage which is a peak detector (like your schematic). Many voltage multipliers are made from Villard cells, that is, diode-capacitor pairs which act as charge-pumps.
The Dickson type is made from one or more H-bridges (using transistors or mosfets). These steer current (similar to diodes), and so a diode does not always appear in the final output stage.
