PCB layer cut-out underneath standard 5x7 oscillators
o2blom
Hello There !
Is there any good reason to cut out all the layers underneath a standard 5x7 (25mhz) oscillator device ? I've seen this done in some designs, but currently space is very limited so I would like to route signals below it.
Thanks,
/Otto
It is not good advice to route to other signals under crystal which will effect both crystal and routed signals...
It should not be a problem as long as there is a solid (ground)plane between the signals and the Oscillator.It will isolate the noise.
