remz
Newbie level 1
positiv 20 uneven bubbles
Hi all,
First post, so please bear with me if I don't follow your general board guidelines.
I have a modest PCB setup at home using photosensitive boards. These are the symptoms of the boards problems.
1. Not all the copper which is to be removed actually gets etched away (see figure attached).
For the board shown in the figure, it was evident that the copper around the edges was not coming away in a timely fashion, so the board was then placed back in the developer solution for a short while and re-etched. This greatly helped remove the unwanted copper however, by this time, the etchant was also havign a go at the tracks.
Currently, I use 5min for the UV which I have found works well. Around 2 minutes for the developer and the etchant time varies from around 30min - 1h30 and his highly dependant on ambient conditions.
A later board was left in the developer solution for 3min and whilst the effects were greatly reduced, a small patch of copper still remained, again, positioned slightly off the edge.
I will be making some more boards today. What should I do, increase the exposure time or increase/decrease the development time. Currently, the board is kept in the development solution until the tracks are clearly visible...and then a bit.
Regards,
Rem
Hi all,
Regards,
Rem
