Potting High Voltage PCBs
cdpstu
Newbie
Nice to meet you all,
I'm exploring potting high voltage, low power PCBs (~5kV) and the possible reduction in distance between components.
After potting a PCB with a good CTI in a low pollution environment, do you have to consider the effects of tracking between components along the boundary between the potting compound and the surface of the PCB, or can it be completely ignored?
It sounds too good to be true - once there is no longer any pollution, the limiting factor is the breakdown of your materials, which can be in the order of kV's/mm making the layout tiny!
I'm guessing there is more to it, it would be great to know what your thoughts are!
wwfeldman
Advanced Member level 3
i suggest you do consider the possibility of arcs between the PWB and the potting compound
i have seen a high voltage unit fail when it arced right along the boundary
between the transformer oil insulator and the fiberglass PWB
we ended up cutting a slot in the PWB, thereby lengthening the path, or forcing the arc to go through the oil
problem solved
FvM
Super Moderator
Staff member
Bochum, Germany
IEC 1010 is requiring 1.5 mm distance at 5 kV working voltage between conductors on the same layer for moulded and potted parts, the same as for inner PCB layers. Obviously, a homogenous interface between PCB and potting material is presumed.
It should be noted that IPC 2221 6.3 is suggesting a clearance as high as 11.5 mm at 5 kV for internal conductors. The numbers aren't substantiated in the standard. We can guess that they consider failure mechanisms like CAF (conductive anodic filament growth). In other words, you should worry more about internal voltage strength of the PCB than of the molding, at least with standard FR4 PCB.
--- Updated ---
Internal horizontal PCB clearance requirements, IEC1010 versus IPC
Working Voltage [V]IEC61010 Table 8 [mm]IPC 2221 6.3.1 [mm]IEC V/milIPC V/mil
8000,1120320
10000,151,516917
12000,2215215
15000,32,7512714
20000,45411313
30000,86,59512
40001,298511
50001,511,58511
cdpstu
Newbie
problem solved
Thanks! It does look like with these kind of potting and encapsulation techniques, you either do have very good insultation or it's failed and it's all gone - there's no in-between. I'll see if I can design in some slots so the epoxy is more like a barrier.
--- Updated ---
--- Updated ---
8000,1120320
10000,151,516917
12000,2215215
15000,32,7512714
20000,45411313
30000,86,59512
40001,298511
50001,511,58511
Thanks for the help!
That is an incredible difference between the two standards, this is for a measurement system so it looks like we could push it into a very small package.
It's looking like creepage is no longer the problem and, as you say, I should be looking more into other failure modes such as breakdown/CAF.
Easy peasy
Advanced Member level 5
Melbourne
the biggest issue is voids, all the E field concentrates over a void - if the material breaks down to SiO2, i.e glass, then the voltage withstand will be OK, if it breaks down to a carbon compound - then things tend to get worse ....
LaTeX Commands Quick-Menu:
