PC out of scope problem in mikroC PIC
Nikola010
Newbie level 6
Newbie level 6
I am making some code, where i read some files from SD card and analyse it. After some programming when i start debugger it says PC out of scope. When i delete for loop in line 480 it work well, but obviously i need it there. In attachment is whole project. What is the reason this error pops out? I didn't full the ROM or RAM memory, and i didn't make too many return routine.
View attachment Master.rar
The problem specification is somehow scarcely. You would want to mention the involved processor and debugger tool.
I presume you are performing source level debugging. So "out of scope" can happen if code execution stops in a code part without debug information and available source code. The usual solution is to inspect the actual PC and the code at this location.
Common cases are:
- processor performed an unintended reset and debugger stops at PC = 0. Reset cause register can tell you more.
- debugger stopped in an exception handling routine (for those processors that have it, e.g. PIC32)
- regular code outside the debugger scope, e.g. a compiler built-in function or library without source, or source not linked to the project. A disassembly or low level ROM view can show the actual code.
Thanks for answering,
I was using mikroC 6.0 and after i got this error, i upgraded it to 6.5 but still nothing. Error code was 0x0010C0 if that mean anything to You. I still didn't test it on real hardware, i just run it in mikroC and proteus. Should this program work in real hardware, because building project doesn't give any error?
Perhaps it wants a short filename version for the folder or needs "Quotes"
warning: 0 1501 Specified search path does not exist: 'F:\mikroC PRO for PIC\defs'
warning: 0 1501 Specified search path does not exist: 'F:\mikroC PRO for PIC\uses\P18'
warning: 0 1501 Specified search path does not exist: 'F:\MikroC\mikroC PRO for PIC\defs'
warning: 0 1501 Specified search path does not exist: 'F:\MikroC\mikroC PRO for PIC\uses\P18'
I don't get that message, but anyways what should i do? Change name of what file?
