patch antenna simulation by using CST Microwave studio
key_
Newbie level 6
Newbie level 6
hai all ......
I decided to make a patch antenna and I need to design it in cst microwave studio...I am new to that software ....so how can i do the simulation..?
Thanks for your replay CG021079 .....
I also need more help about single feed corner truncated circular polarized patch antenna.....and how to improve the gain and bandwidth of such antennas......
Regards key_
you can check the folder c->cst>documentation (in your system). all manuals are available there.
You can tried Antenna Magus, and then export the file to CST.
Regards
any one know what is a differance btw e plane and h plane pattern in cst and how i can plot these two pattern with cst
Amntt,
Here you can find good info about what you want to design:
https://www.jpier.org/PIER/pier80/03.07110604.pdf
E and H plane are just the definition of the two perpendicular planes where E and H are higher respectively ad you can observe rad pattern just by changing your view,(i.e phi =0 --> phi = 90)
Regards
Hadi
Alberto,
Do you have Magus? I just want an dual-reflector antenna design example for 1 GHz exported for FEKO. Can you help me for that?
Regards
Hadi
