[SOLVED] patch antenna input impedance in CST
lkminz
Member level 4
hi there
for any operating frequency i could obtain the patch length and width. i can also calculate the width of the 50 ohm feed line .. but for proper matching antenna input impedance need to be known ...
how to determine antenna input impedance in CSt .. i know after simulation one can get impedance at port..... is there any way to get impedance at feeding point of antenna?
if input impednce at feed point is known then i can use a trasformer with proper width and length for matching. there should be a ways to calculate edge impedance in CST if any one knows about it then plesae help me here ...
regards
lkminz
hi
you can find the antenna input imedance after simulation
just click the result in the menu bar, there you will find the S parameters calculations and inside which you will see calculate Z and Y matrices
ater selecting Z and Y matrices you will find the input impedance result in the 1D result folder
regards
hi lkminz,
if you are doing microstrip feeding then you can match the impedance for 50 ohms.
regards
hello
anybody can show me how to calculate impedance matching for 50 ohm impedance for the microstrip antenna
hi caihalo
matching is calculated on the basis of S11 measurment for microstrip antenna. for a properly matched antenna S11 should be less than -10 dB at the resonanting frequency of the antenna.
i got the answer of my question.. after simulating a guess work one can find port input impedance as shahid78 explained or just by checking smith chart plot which shows input impedance at the right corner
then by deembedding antenna input impedance of antenna, in case of microstrip antenna , can be determined.
i hope after that just a appropriate trasnfer is required to match it properly.
thanks all for discussion and help
